Aha! Time time draws near, I’ve got a set of beta PCB’s arriving tommorow which I will do my best to stuff and solder this weekend. Barring unforseen problems with the layout I am on schedule to do a run of PCB’s in mid-late August. I will be providing with the PCB nearly all the difficult to find components, including alot of the original sillicon.
There is also a fellow who has been working hard to create a REALLY REALLY nice case for the clone, details to come.
If your interested in building your own 808 send me an email at smeffasystems@gmail.com to get on the list.
The original circuits have been included, and I’ve also added in most of the modifications that hallucinogen did for his clone.
The sounds will be triggered from a stripped down MBSEQ, which is included in the PCB, some extra code still needs to be written to allow the sounds to be triggered via midi.
Ah, nifty. So you’ve got permission from TK to include MIOS in something you are selling? Congrats.
Got any more info about the board layout, dimensions, anything like that? I’m interested, but I want more details first…
This is a clone of an analog synth. Making the sounds programmable via MIDI would be an amazing amount of work, and thusly make it no longer a proper clone.
Actually, it’s remarkably easy to put some parameters such as TUNE or DECAY under CV control using just a resistor and a transistor. How you’d interface the CV to the sequencer I don’t know, I guess you could have an ‘Automation’ track or something.
Hi toxic… What’s the aim of your project? It sounds like “re-inventing the wheel” to me… You’re doing synth layouts like hallucinogens, and building a sequencer from the ground up…
So why not just use hallucinogen’s synths and a MBSeq?
Count me as interested too. I’d need to hear a price first of course.
Also, would it be possible to tap off the triggers from your board to trigger external analogue modules? I mean by the builder. What’s the trigger voltage?
Trigger voltages are 5v. The 808 itself uses a 5-15v pulse for the accent signal. I don’t have anything to test with, but it is my assumption that you can just tap the 5v pulse for trigger. I’ve got a header on the board for doing this, and there is a simple buffer there to drive a LED which I’m pretty sure can do double duty.
Check out the WIKI page, I’ve got a description of how it all works there.. just text tho so it may be rough to read..
