At a first glance I don’t see a configuration error.
However, I think that this combination can lead to unstable SRIO transfers because of the high number of SRIOs and different chain lengths of the DIN/DOUT SRs. This would also explain, why the BLM acts strange.
I don’t know how exactly your hardware looks like, but if the TPD is close to the wilba frontpanel, then it’s sufficient to connect the transmitter/receiver between TPD and BLM4x16
I don’t understand the behavior because I have used it for a while with the TPD connected after the BLM, and it’s worked fine.
The only reason I changed it was because I saw that I could get a shorter cable if I connected them in the reverse order.
My hardware looks like this
On Wilba’s frontpanel the DIN/DOUT connectors are on the left side.
On the TPD they are next to each other, but on the BLM the IN is on the left side and the OUT is on the right.
It made sense to me to keep the cable stretches as short as possible, so I tried Core -> Frontpanel -> TPD -> BLM with the attached config file, but I ran in to the problems mentioned.
I guess I should follow the “If it ain’t broke, don’t fix it” rule.
I’ll just revert back, shut up and make some music
i have tried this with the Line Driver Transmitter/Receiver…(because i wanted more distance between Sequencer and BLM/TPD.
But in my case it did not work…with the linedrivers the buttons/leds were acting strange…
and when i removed the linedrivers and connected it with flatcable…it worked okay…(i know the linedrivers are also okay as ive also used them with the Aout-NG without any problems)
The problem is, that the TPD has many DOUT shift registers, but only a single DIN shift register (as far as I remember). This results into an unbalanced serial output which leads to trouble when another module with DIN/DOUT registers (such as the BLM16x4) is connected.
So - this kind of module will only work at the end of a serial chain, or with some buffering (and some luck) - it’s a complex topic, I can’t give you a fool-proven solution without further analysis (and I won’t have the time for this anyhow…
That is right, there are 9 DOUT shift registers but only 1 DIN. It seems best to simply leave the TPD at the end of the chain and ignore the OUT port then.
OK. I have reverted back, and it works fine like before.
I wanted to add some gate triggers, so I guess I have to add them before the TPD then, or can anyone suggest an easier/better way to add 8 gate triggers?
As the gate triggers are not arranged in a matrix configuration it should not matter where in the chain they are located. I guess the critical timing issues only arise when matrixing ins/outs. For these (like the BLM), an equal number of DIN and DOUT SRs should precede in the chain to keep the timing undistorted.
