Hi !
(MB64 & Mios 1.7)
i have test the touchsensor
with sensibility set from 1 to 32 and
it still send 0, 127, 0, 127… in loop when i touch it. ???
any idea ? can i really use a touchsensor like a button ?
or it’s normal ?
thanks very much ![]()
Hi !
(MB64 & Mios 1.7)
or it’s normal ?
I can only say that it should work (even with the default sensibility setting) without toggling, just like with a normal button. How does your touchsensor look like?
my touchsensor now (testing) is a simple
copper / epoxy board with the appropriate resistor
and without the DIN resistor, like recommended on the site.
so, i keep on searching the solution.
thanks thorsten ! ![]()
hi !
it’s strange, when i plug my midibox directly on my cheap casio synth
the touchsensor work very well !! (great things… :D)
but when i plug my midibox into my soundcard (Echo Layla24)
the touchsensor send 0,127…in loop, even if i change the touchesensor sensibility .. ???
any idea ?
