Touch-senstive encoders
Does anyone know where to get or how to make touch-sensitive encoders similar to Digidesign Icon series controllers and other high-end controllers?  If these are not available, maybe they can be made by using some sort of proximity sensor technology.  Thanks.
… just use the encoder’s ground pin not for ground, but to connect to your touch sense input (certainly a conductive knob is needed). Any encoder with metal shaft should basically work.
If you don’t handle the sensing in the PIC, you can use e.g. http://www.qprox.com/assets/Downloadablefile/qt102_2r3.05-15437.pdf
Greets, Roger
