almost 6 hours of soldering of my new midibox…
i’m VERY VERY VERY tired… an di think that tomorrow i have to work for another 2-3 hour to finish… hoping that all the connections wil be all right!! ![]()
think your next MB wireless!!! ![]()
Building my midi interface for a joystick port was also pretty long : 3 outputs in parallel with on/off switches and 2 caps per plug, 2 switchable inputs also with caps, hex inverter and optocoupler, also a diode. The thing is that I built that on veroboard and the switches and connectors are mounted directly in the plastic box, I’ve done point to point wiring with CAT5 on the PCB, and it was REALLY long.
Count yourself lucky if you have a pre-made PCB, that’s not too hard to do. If you use veroboard, I understand what you mean. Which MIDIbox are you building?
i was building the midibox16E with 16 encoder and 16 pots + some other gadget (see the gallery!)
