Hi!
I just got hold of some switching PSU. Got it to work, buy putting a Led and a resistor on the 5 V and some laps on the 12 V.
The only problem is the 5 volt output gives me 5,35. Stupid. Do you think this will drop when it gets more load? 5.35 is not enough to run it trough the 7805 but I guess too much to go directly to the core. Since the same psu has quite a bit of ripple to, I was wondering if anyone has found (and tested) a replacement for the Fortron psu mentioned in the Switching pdf?
Sorry for all my psu posts
Thank you
Nikolai
