Is it possible to use toggle switch with MIDIBOX SID ?
I want to use some for parameters that have only two states, for instance edit mode (on/off) enveloppe(1/2) link etc
I’m just beginning so as far as programming is concerned I don’t know much :![]()
Currently toggle switch works but not in toggle mode, I mean the switch has to be in the same state for the parameter to change (for instance if env 1 is selected when switch is on then when going to off state nothing happens and when going back to on state it changes to env 2. And then going to off again doesn’t change etc)
It must be easy but I didn’t grasp the code so far…
