TK: BLM16x16 + X
Album by TK.
Follow the progress of the BLM16x16 (+X ;-)) project
An idea to join multiple veroboards
All buttons mounted
After 2023 solder joints
A nice flat case for the BLM (+X)
Ikea Ribba 30x40 cm for 10 EUR
Guaranteed worldwide available :wink:
Interfacing a SRIO board sandwich-like
Why not adding faders at both sides
Lightfest and “button cap” test for the first quarter
Usage of 2-row SIL headers to ensure the correct distance between boards
Later we will use such 2-row SIL headers to mount the SRIO boards
…and to connect the matrix wires
Please note: soldering such filigree wires is time consuming and requires some dexterity.
It will work perfectly with double layer PCBs, but if you really consider to build the BLM on a prototype board like me, it’s probably easier to add sockets at the bottom of the PCB (thats my conclusion after all the work)
Picture of the SRIO boards (15 DOUT SRs, 5 DIN SRs)
SRIO boards mounted on the bottom
“Multi Layer” :wink:
0.6 Ampere
My first pattern :wink:
Re: All buttons mounted
Bored again i see? :stuck_out_tongue:
I was staring at that pic for a long time,
thinking it was just one perfboard,
and was trying to figure out what these metal hole like things were sticking out of it,
until i realized it was a photo taken much higher than i thought, of multiple perfboards, and lots of buttons!
curious of which project this could be part Â
Re: A nice flat case for the BLM (+X)
Haha! Yet another innovative way to use IKEA stuff :thumbsup:
Re: After 2023 solder joints
WOW! :sorcerer:
Re: An idea to join multiple veroboards
very clever, the alignment still works? Or is some filing/shaving involved?
“Guaranteed worldwide available” yeah right, please show me an ikea store here in mexico city TK :wink:
No filing required - I only had to reduce the size of the middle boards with a cutter so that the second button row is between two boards (was done in 1 minute).
Thats the reason for the small gap between second and third board row. But this gap doesn’t hurt, the distance between buttons stays identical.
Insanity… :slight_smile:
Re: Why not adding faders at both sides
http://3.bp.blogspot.com/_0YTZJpJ8Jp8/Sj8Yc2lejaI/AAAAAAAAFiI/IWxcJWzLRo0/s400/excuse_me.jpg
I was thinking of a monome type thingy at first,
But now u haz added sliders so i was lik ,
wtf i dunno.
It’s a big BLM for SEQ… though I have pondered more non-linear uses as well. :frantics:
Eagerly awaits schematic.
Re: Lightfest and “button cap” test for the first quarter
yeah :slight_smile:
I’ll probably (re)build a gear like that one day.
I did the bonome with arduino framework, I’ll definitively use midibox framework for the new one!
Re: My first pattern :wink:
weeeeeeeeeeeeeeeeeee heeeeeeeeeeeeeeeeeeeee!
:slight_smile:
nice1
Re: “Multi Layer” :wink:
KAN HAZ CIRCUT DIAGRAM 4 DIS??
respect :thumbsup:
damn looks like the floor after i went to the barber :slight_smile:
Dear Tk,
I would like to know what is the wire you use to make this one?
thank you
Xarolium
crazy stuff :turned:
