The CONFIG_MIDI_IN table
I see this mentioned in most of the apps as sort of a “preset” table for incoming MIDI (guessing), but they all seem to have their own tables for that under different names.
Does a CONFIG_MIDI_IN table actually exist somewhere?
Thanks,
George
Yes, it’s located in mios_tables.inc, the name is “MIOS_MPROC_EVENT_TABLE”, and on matches the USER_MPROC_NotifyFoundEvent function will be called.
I must clearly say, that it was a bad idea to add such a feature to MIOS, as most applications need an individual MIDI handling with different data structures. It’s also not possible to realize, that a Note Off event will turn into a Note On with velocity=0 w/o duplicating table entries.
On the other hand: this is the fastest parser you will find especially for CC’s
Thanks TK!
Didn’t realize the name would be different (I had been searching everything for an exact match).
George
