OK, first question. Will the following rotary encoders be able to be used on the mbSID?
Specifications:
Weight: 11g
Electrical Output: 2-bit gray code
Closed Circuit Resistance: 3 ohms
Contact Rating: 1 mA at 5 VDC
Insulation Resistance: 10 megohms at 250 VDC
Dielectric Withstanding Voltage
Sea Level: 50 VAC minimum
Electrical Travel: Continuous
Contact Bounce (15 RPM): 5.0 ms.
RPM (Operating): 100
Mechanical Angle: 360° continuous
Running Torque: 30.6 to 204 g-cm (0.42 to 2.83 oz.-in.)
Shaft Side Load (Static): 2.04 kgf (4.5 lbs.) minimum
Weight: 3 gm (0.1 oz.) max
Operating Temperature Range: -30 °C to +70 °C (-22 °F to +158 °F)
Storage Temperature Range: -40 °C to +85 °C (-40 °F to +185 °F)
Humidity: MIL-STD-202, Method 103B, Condition B
Vibration: 30 G
Contact Bounce: 10~55~10 Hz / 1 min. / Amplitude 1.5 mm
Shock: 100 G
Rotational Life: 30,000 cycles minimum
Switch Life: 20,000 cycles minimum
IP Rating: IP 40
Wave Soldering: Sn95.5/Ag2.8/Cu0.7 solder with no-clean flux: 260 °C max. for 3-5 seconds
Hand Soldering is NOT recommended
Power Rating (Resistive Load): 10 mA at 5 V DC
Switch Travel: 0.5 +0.4/-0.3 mm
Switch Actuation Force: 360 +153/-102 gf (5 +2.1/-1.4 oz.-in.)
Im aware of what kind of pots are needed for the MB64…but I couldn’t see it written where it says what kind of encoders to use? Could their button function be used to trigger anything on the mbSID? or would it be useless?
