testing of the CORE module for SID use...
i have just terminated my CORE module for my SID project.
i will do the test in the following days, because i lack the connector for the power supply,. so there is time for some questions! :slight_smile:
  1. is there any kind of test i can do (apart the voltage control) in order to be sure that the core works, after PIC programming and PC MIDI connection? (some sort of sysex/MIDI communication with MIDI-OX for example…)
  2. i have used a TL05 voltage regulator without heatsink… is it safe??
  3. i will not mount the LCD screen. will i have to connect the two trimmers P1 and P2? should i connect a resistor or leave the contacts open??
  4. all the connectors not used in the SID configurations should be leaved open, right? :slight_smile:
  5. i have a power supply at 16V 800-900mA (don’t remember…) is it OK for powering both module??
thank you very much!!
matteo
Hi Matteo,
yes, you could send a “ping” command to the core: f0 00 00 7E 46 00 0F F7
The same string should be returned.
  1. i have used a TL05 voltage regulator without heatsink… is it safe??
Yes, because the power consumption is very low.
  1. i will not mount the LCD screen. will i have to connect the two trimmers P1 and P2? should i connect a resistor or leave the contacts open??
In this case P1 and P2 are not required
  1. all the connectors not used in the SID configurations should be leaved open, right? :slight_smile:
yep :slight_smile:
  1. i have a power supply at 16V 800-900mA (don’t remember…) is it OK for powering both module??
yes, perfect. You could also use a PSU with 200 mA
how can i send a ping to the core? with midiox?
yep
but how   ???
Open MIDI-OX , open the SysEx window and send this command:
I have just finished building my MIDI core (based on the PIC 16F877) and all was working fine, then after a while, things stopped working.
I re-sent the SYS-EX file, and unlike before, no return on information.
I tried re-programming the chip, but again no joy.
After reading the above message i tried to ‘ping’ my core, but nothing came back.
Have i blown something, could anyone suggest what, and how i might find out?
Many Thanks
Michael
have you checked all connections, voltage on the supply pin of the chip etc?
I’ve tested all the voltages and they seem fine.
I’ve tried the test programs on my chip, and the test_txrx one which should just pass MIDI information through does pass information through, but its generally nothing like what i sent in.
It seems very strange because like i said everything was working, i just left it for half an hour and when i came back things didn’t seem to respond.
Thanks
Michael
