I’m building a midibox64 and i’ve finished the core module. Measured voltages and everything is OK, programmed the PIC with the 0.034b firmware.
I wondered if i’m able to do a quick test with one pot connected to A0 of J5, A1-7 connected to ground (thus without needing to connect an AIN module)?
Do i need to connect anything else? Other ways to quickly test?
Sorry if this sounds like a super newbie question, 'cos i am! ;D
You can also check it without an AINX4 module - the MIDIbox64 will send 8 values at the same time due to the missing multiplexer, but for testing purposes this is ok - your schematic is correct.
I wanted to verify this because i wasn’t getting *any* MIDI output at all.
The problem seems to be my PIC programmer… Although i get a programmed & verified OK (verify during and after switched on) - if i read the PIC i get nothing but zeros… ???
