Hello Boxers !
I am coding an application in C that request a dump of 100 patches from a synth
Each patch is sent every 132ms, one after another
Patch is 275 bytes. Only 134 bytes are useful to describe the patch, the rest is checksum and sysex tag
A sysex parser has been developed and works good with ONE patch
the 134 bytes are then written onto Bankstick
I’ve tried an automated algoryhtm to directly write the 100x134 bytes in Bankstick but PIC reset : it goes too fast.
So, i’d like to measure the time that does each task
According to ucapps website, writing the banksick takes 30 ms (3 pages of 64 bytes)
But what about the rest ?
// see: http://wolzow.mindworks.ee/analog/m1k-midi-spec.htm
// edit buffer received f0 10 06 01 <patch num> <patch data> <checksum> f7
// xx yy data, sent nybblewise:
// a data byte dd is sent as xx=dd&0x0F; yy=(dd>>4)&0x0F
// cc checksum:
// the sum of the original data bytes dd, masked with 0x7F.
// faire une boucle avec k = 0 .. 99 ; Ã chaq tour de boucle on ecrit le patch
// Ã l'adresse k
// this functin doesn't work : Matrix1000 dumps too fast to write
// only the 1st patch is saved, 2nd is buggy, the rest is out
void MIDI_HandleBankDump(unsigned char byte)
//appelle une sorte de "handle edit buffer"
unsigned char program_received; // will be used to write is K
static unsigned char editbufferstatus;
static unsigned char firstnibble;
static unsigned char ebparam;
static unsigned char lsb;
static unsigned char bytecount;
unsigned char error = 0;
unsigned char checksum = 0;
if(program_received < 99)
switch(editbufferstatus)
case 0:
if(byte == 0xf0) //premier byte envoyé par m1000
editbufferstatus = 1;
else
editbufferstatus = 0;
break;
case 1:
if(byte == 0x10) ///2eme byte envoyé par m1000, mfg
editbufferstatus = 2;
else
break;
case 2:
if(byte == 0x06) ///3eme byte, correspond à "M1000/M6", code machine
editbufferstatus = 3;
else
break;
case 3:
if(byte == 0x01)
editbufferstatus = 4; ///single patch data
else
break;
case 4:
if(byte == program_received) // notice patch number (0-99)
editbufferstatus = 5;
lsb = 1;
ebparam = 0;
program_received = byte;
else{
break;
case 5: // voice data
if(ebparam < 134) // 134 = number of voice parameter bytes
if(lsb == 1) // first nibble, least significant byte
firstnibble = (byte & 0x0f);
lsb = 0;
else // second nibble, most significant byte
EditBuffer[ebparam] = (byte << 4) + firstnibble;
EditBufferOrig[ebparam] = (byte << 4) + firstnibble;
lsb = 1; // reset
ebparam++;
else // status 6 checksum skip to 7
editbufferstatus = 7;
checksum = byte;
break;
case 7: // sysex end
if(byte == 0xF7){
UpdateDinStates();
Write_Patch_To_BS(uBS_uBank, program_received); // write received patch
program_received ++; // ready for next patch
else{
error = byte;
break;
else{
MIDI_ReceivingBank = 0; // tag "end of receiving a bank"
#if DEBUG
MIOS_LCD_CursorSet(0xc0 +8); MIOS_LCD_PrintCString("finished !"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
// Receiving a whole bank, patch one by one : reboot PIC ! too much received data at once
void MIDI_RequestPatch_onebyone(unsigned char bank, unsigned char ubank)
unsigned char k;
MIDI_SendPatchBank(bank);
while( k < 99){
ProgramNumberReq = k;
MIDI_SendPatchProgram( k);
MIOS_Delay(10);
MIDI_RequestEditBuffer(k);
MIOS_Delay(60);
Write_Patch_To_BS(ubank, k);
MIOS_Delay(130);
//program_request_1b1++;
k++;
#if DEBUG
#endif
// This function returns a byte from patch structure in RAM
unsigned char PATCH_ReadByte(unsigned char addr)
return patch_structure[addr];
// This function writes a byte into patch structure in RAM
void PATCH_WriteByte(unsigned char addr, unsigned char byte)
patch_structure[addr] = byte;
// This function read a patch stored into BS
// This function loads the patch structure from EEPROM/BankStick
// Returns != 0 if Load failed (e.g. BankStick not connected)
unsigned char PATCH_Load(unsigned char bank, unsigned char patch)
unsigned char i;
#if PATCH_USE_BANKSTICK
// determine offset depending on patch number
unsigned int offset = (patch << 7) + 7; // default : patch << 8
// select BankStick
MIOS_BANKSTICK_CtrlSet(bank & 0x07);
// use 64byte page load functions for faster access
for(i=0; i<3; ++i)
error = MIOS_BANKSTICK_ReadPage(offset + i*0x40, (char *)(patch_structure + i*0x40)) ;
#if DEBUG
if (error == 0x02){
MIOS_LCD_CursorSet(20+11); MIOS_LCD_PrintCString("no BS"); MIOS_LCD_PrintHex2(error); MIOS_LCD_MessageStart(TMP_MSG);
}else{
MIOS_LCD_CursorSet(20+11); MIOS_LCD_PrintCString("error"); MIOS_LCD_PrintHex2(error); MIOS_LCD_MessageStart(TMP_MSG);
MIOS_LCD_CursorSet(0xc0 +11); MIOS_LCD_PrintCString("_LoadBS"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
#else
// ignore patch and bank
for(i=0; i<3; ++i)
MIOS_EEPROM_ReadPage(i*0x40, (char *)(patch_structure + i*0x40));
#if DEBUG
MIOS_LCD_CursorSet(0xc0 +11); MIOS_LCD_PrintCString("_LoadEE"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
#endif
return 0;
// This function stores the patch structure into EEPROM/BankStick
// Returns != 0 if Store failed (e.g. BankStick not connected)
unsigned char PATCH_Store(unsigned char bank, unsigned char patch)
unsigned char i;
unsigned int offset = (patch << 7) + 7 ; // default : offset = patch << 8
// select BankStick
// use 64byte page write functions for faster access
for(i=0; i<3; ++i)
error = MIOS_BANKSTICK_WritePage(offset + i*0x40, (char *)(patch_structure + i*0x40)) ;
#if DEBUG
if (error == 0x02){
}else{
MIOS_LCD_CursorSet(0xc0 +11); MIOS_LCD_PrintCString("_StoreBS"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
#else
for(i=0; i<3; ++i)
MIOS_EEPROM_WritePage(i*0x40, (char *)(patch_structure + i*0x40));
#if DEBUG
MIOS_LCD_CursorSet(0xc0 +11); MIOS_LCD_PrintCString("_StoreEE"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
#endif
return 0;
/// read a patch from a BS
void Read_Patch_From_BS(unsigned char bank, unsigned char patch)
unsigned char j;
PATCH_Load(bank, patch);
for (j=0; j<134; j++){
EditBuffer[j] = patch_structure[j];
#if DEBUG
MIOS_LCD_CursorSet(0xc0); MIOS_LCD_PrintCString("Read_Patch"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
/// write a patch to a BS
void Write_Patch_To_BS(unsigned char bank, unsigned char patch)
unsigned char j;
patch_structure[j] = EditBuffer[j]; // ok ça marche :)
PATCH_Store(bank, patch);
#if DEBUG
MIOS_LCD_CursorSet(0xc0); MIOS_LCD_PrintCString("Write_Patch"); MIOS_LCD_MessageStart(TMP_MSG);
#endif
Thanks in advance if you 've some trick
Best regards
Julien
