Tap tempo question
So I really like how the tap tempo functions on the sequencer, but for me I always get results that are way way faster than I feel they should be. I have used tap tempo on tons of devices over the years, and I have even compared tap tempo apps on my phone vs the sequencer, tapping to the same song I am trying to match. Does anyone else see this issue or is it just my bad tapping? On Maschine for example I always get what I feel is pretty close.
Thanks,
Luke
Hi Luke,
I will test the accuracy with a digital pulse generator soon (just added this to my TODO list)
hellos,
been testing things on my unfinished midibox seq4 (lpc17) .. and i can confirm that the tempo tap doesn’t work as expected, it’s a good deal too fast (110 instead of 90 bpm eg) ..
Thanks for the input! This pushes the priority on my TODO list! :slight_smile:
But I won’t have to possibility to check this before next week.
Question: are you using Wilba’s Panel?
And how do you tap the tempo - with MENU+PLAY, or in the BPM page?
Not Wilbas here, custom with a dedicated tempo tap button. It’s the same with Menu+Play and BPM page for me.
Got it, fixed it!
The tap tempo function was calculating with 5 taps based on the delay measured for 4 taps - therefore the resulting tempo was too high.
In v4.064 it should work very accurately now! :slight_smile:
Thanks, working perfectly now (:
Fine! :slight_smile:
Hello,
I still experience too fast tempos with the tap tempo function on my seq4l.068. If I tap along a beat, it speeds up! I have both the newest firmware and the new bootloader. Strange, not?
Edit: found it and solved! The seq4L file seq_ui.c function 3SEQ_UI_Button_TapTempo() still had the old code. I checked in file seq_ui_bpm function SEQ_UI_BPM_TapTempo() of the big seq4. The bpm calculation was different, so I put big seq4’s version in and Bingo!
// original seq4l version: comes up with too high tempo
    // u32 bpm = 60000000 / (accumulated_delay / tap_tempo_beat_ctr);
    // new version copied from the large seq4 seq_ui_bpm.c function SEQ_UI_BPM_TapTempo
    u32 bpm = 60000000 / (accumulated_delay / TAP_DELAY_STORAGE_SIZE);
Thank you very much! :slight_smile:
The change is in the repository now, and it will be available with the next release.
fixed in V4L.069
