System error help?
Hello.  Just to start off, I’m not a DIYer.  I bought my MB6582 from a site member here about 2 years ago.  With some help I’m hoping I can fix the issue…
I control the 6582 via external MIDI.  Last night when playing live from my controller through ProTools, the 6582 seemed to receive a control message that caused it to stop receiving notes.  The display looked like it was running a script of sorts and when it finished, it loaded patch 1 but would not play.  I cycled the 6582 off and when I powered it back up it started as normal and loaded patch 1.  However, after about 5 seconds (or so) it rebooted and then continued this cycle indefinitely.
I’m assuming I will need to reload software, but wanted to check with the forum before proceeding since this is the first time I will be attempting something like this.  All help is greatly appreciated.  Thanks in advance!
It could also be a failing PSU - do you use a native Commodorde power supply? Can you measure voltages on the MB6582 mainboard when it is powered on?
orange_hand created an excellent infographic showing “necessary” voltages:
http://discourse.midibox.org/t/topic/16364
Many greets,
Peter
