Sync the Sid again!!
Hi there!
Just an question..I´m using the sid firm 1.5c.
And I can´t get  sync of the arpeggiator.
I have the rate of the WT to 123 (as Thorsten write before) And the Clk in CFG menu to W_ _.
And I´m sendig the MIDI Time code from Cubase SX.
Should I go back to the SID 1.5b or…
Thank´s
Christoffer
Hi Christoffer,
not the MIDI time code, but MIDI clock has to be sent by your application.
Hi!
Allready tried that…
Doesn´t work!!!  :-/
Maybe I´m forgot something…??Or maybe I´m just stupid.. :wink:
Christoffer
Could you try the MIDImon application? It should display the correct BPM - if not, check your Cubase setup.
Note that MIOS V1.4b is required to get this working!
Yeah!!
Working  ;D ,The problem was I got the MIOS ver.1.3..
Another question:The rate (in the WT menu) how do you know that the value should be 123 for 16th note?
If I want it to be 4th note?? Do I have to be an matematic professor or something??  ;)
Thanks!!!
Christoffer
I’ve planned to improve this in the future (do avoid more questions regarding this topic :wink:
Maybe a big “what to do if it doesn´t work” - FAQ would be helpful, wouldn´t it? There are often questions coming up again and again (like that “I´m getting random data” - AIN question and stuff).
Idea?
sorry :-[ :wink:
Christoffer
