Switch with integrated display
Hey!
I just took a look at the great midas mixing consoles. They use switches with integrated displays, which is really fancy.
After a bit of googling I found out that NKK Switches produces them. They are very expensive (50€ and more).
I wonder if those switches are compatible with MIOS! Here is a link to a datasheet:
http://www.nkkswitches.com/pdf/IS15EBFP4RGB_Wide64x32LongTrvl.pdf
I don’t think that it makes sense to put effort into this if MIOS doesn’t support it already, because nobody will use them later on… they are too expensive. So I’m just asking :wink:
Thanks
Chris
I’d be interested as well, as I have about 30 used ones kicking around somewhere. But I doubt that I ever get the time to try them out myself. Also, they come in different screen and color resolutions.
Hey!
I just want to grab this out again. Maybe TK is able to give us a quick “yes” or “no” on this topic :slight_smile:
Here is another distributor of those displays:
http://www.wellbuying.com.tw/UP_pdf/PS007.pdf
