Switch cap and acrylic panel
Hi everybody.
First I would like to ask to people that have already experienced the famous couple TL1100F160Q (switch) / C&K PE BK (cap switch) what should be the better aperture size for 3mm acrylic panel with a standard spacer of 10mm? I found differents sizes for differents projects (sammichSID, x0xb0x, Shruthi, …).
Second question: Did anybody used the medium grey acrylic panel of Formulor.de with (red) LED regarding the tranparency?
Thank you.
Best regards.
Not to nitpick, but the Shruthi and the standard Ambika use the smaller TACBLK and similar caps. NOT the TA12-series or the PE-BK/WHT etc.
Best,
J
Thanks jojjelito.
It’s exact, I didn’t realize that before (certainly because I planed to use PE-BK/WHT caps during the casing of my Shruthi)!
Regards.
To further nitpick :wink:, that Sammich uses the TA12 series. These are 5,70mm width, the TAC series which are used in the Shruthi are 5,5mm
Hi jojjelito.
Is TA12 series equivalent of PE-BK/WHT serie (to be used in MBseq)?
Regards.
Hi jojjelito.
Regards.
Hi J!
Yup they are. If you see different measurements it’s because it is tapered:
/__\
and one of them is measured at the base, the other at the top.
Best,
J
Hi J!
/__\
Best,
J
Hi J!
I call that a professional answer :thumbsup:.
Regards.
