Greetings!
As the title might suggest, I’m planning to build Wilba’s MB6582 design of the MIDIbox SID and I intend to replace the original SID chip with the SwinSID board. There are some questions orbiting my head about this concept. The first and biggest one is: will the SwinSID board fit inside this design? The MB6582 looks so robust that I have my doubts if I can cram extra stuff inside. I need to know also if there are some things I need to keep in mind when building the SwinSID board for MBSID. Also I have some questions about the building process of the SwinSID; can anyone recommend me an European site where from I can order a PCB for the SwinSID (I am assuming there are small business’ which offer manuafacturing services for single PCBs for private users) and where from should I order a programming device for flashing the PLCC44 chips (I could also try building one myself if anyone has to offer DIY-links)?
Thanks in advance and thank you all for this great community which seems to have alot to offer for!
