SwapValues - problems with this meta command
Hello,
I am using MIDIbox NG v1.027. When using the meta command “SwapValues” for swapping “value” and “cc”, the cc seems always to be zero. The “use_cc_numbers=…” also doesn’t help. Everything was working fine in the past.
“In the past” means, an earlier MIDIbox NG version and/or some earlier NGC/NGL configurations.
Of course, my first step was a walkthrough to my NGC/NGL configurations. But after lots of hours and a lot of try and errors, I like to ask, whether one of the newer software updates could be responsible. I haven’t checked this, because I have no older hex files.
Thanks from LINO
Hi Lino,
I can check this, but would need the exact EVENT definition that you are using to reproduce the issue.
