yes ! i have realised that i am absolutely clueless, and it’s a miracle i’ve come this far.
i have completed the core module, and my SID module. the lcd works and i think i have loaded the os correctly.
i finally found a c64 psu. the two pdfs about how to connect them, i have rather basic questions as i’ve managed to arrive here without having to read any schematics.
the 1st pdf, entitled mbhp_sid_psu.pdf - this is not optimised, correct? meaning that it doesnt have the facility to reduce noise, and increase the signal? so if i build this simple one, my questions are 1) how audible is the noise 2) is this circuit meant to be built on a small board or something? 3) i have no c64 - i have to aquire those components elsewhere right?
and, so if i decide to be adventurous and try and build the optimised PSU, that essentially means:
a c64 psu that plugs into another proto board with a bunch of stuff on it that cleans the signal? and that board send the correct voltages to the core and sid?
thanks for anyones time in answering any part of this meganoobness.
