Stuck with programming midibox
Hello,
Can someone help me with solving the following problem when pogramming my midibox?
I’ve managed to upload the bootstrap and the MIOS-OS. No complaints @ all.
Now I’m trying get upload my application to test if all of my 16 endless rotary encoders are working.
I’ve made the following changes in the mios.tables.inc
     ;; encoder entry structure
ENC_ENTRY MACRO sr, din_0, mode
     dw      (mode << 8) | (din_0 + 8*(sr-1))
     ENDM
ENC_EOT      MACRO
     dw      0xffff
     ENDM
MIOS_ENC_PIN_TABLE
     ;; encoders 1-16
     ;;        SR  Pin  Mode
     ENC_ENTRY  1,  0,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 1
     ENC_ENTRY  1,  2,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 2
     ENC_ENTRY  1,  4,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 3
     ENC_ENTRY  1,  6,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 4
     ENC_ENTRY  2,  0  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 5
     ENC_ENTRY  2,  2,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 6
     ENC_ENTRY  2,  4,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 7
     ENC_ENTRY  2,  6,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 8
     ENC_ENTRY  3,  0,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 9
     ENC_ENTRY  3,  2,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 10
     ENC_ENTRY  3,  4,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 11
     ENC_ENTRY  3,  6,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 12
     ENC_ENTRY  4,  0,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 13
     ENC_ENTRY  4,  2,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 14
     ENC_ENTRY  4,  4,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 15
     ENC_ENTRY  4,  6,  MIOS_ENC_MODE_NON_DETENTED      ; V-Pot 16
     ;; encoders 17-32
     ENC_EOT
     ENC_EOT
Now only the first encoder gives a signal in MIOS but the other 15 don’t.
I’ve got a DIN module right @ the CORE @ pin 9 with 16 ALPS encoder to it.
I think my code isn’t ok but I can’t find the problem.
My final design contains 96 buttons, 16 encoders, 17 sliders and 38 leds. Which example from the ucapps-site should I use to re-write.
Is somebody help me programming this thingie?
thanx
echelon
Did you try the ENC example 1?
Then you should continue with ENC example 2 which handles more than 1 encoder… (it always makes sense to read the comments in main.asm ;-))
Thanx Thorsten,
I just re-edited the ‘mios_tables.inc’ from the encoder1 example but didn’t read the info in the ‘main.asm.’
I’ll have a look @ it and will try it again… :smiley:
WHere can i get more infomation for editing the mios_tables.inc file?
With trial and error i only concluded that
MT_ENTRY      0x90, 0x00 - is a note &
MT_ENTRY      0xb0, 0x00 - is a controller.
Is there some where that lists out what the rest like 0x00,0x01… are used to patch to?
Cheers. :slight_smile:
Just fire up Google and search for “midi specification”…
What you are looking for:
8 = Note Off
9 = Note On
A = AfterTouch (ie, key pressure)
B = Control Change
C = Program (patch) change
D = Channel Pressure
E = Pitch Wheel
The lower Nibble (4 Bits) is the MIDI-Chanel:
0x92 means Note On, Channel 2
0x8F means Note Off, Channel 16
Hope this helps
Raphael
Thanks for the list.
I’ve getting some problems. I connected 8 pots to a AIN4X. I’m using the MIOS AIN64 DIN128 DIO128 app.
In the mios_table, i put “MT_EOT” for the pots section. THen for the first eight i placed :MT_ENTRY 0xb0, 0x10-18.
The problem is, when i open one of 2 certain pots, i get lots of random data. When all closed, i can only work 4 pots. But each of this pot sends 2 sets of sysex eg B0-14 and B0-15 or B0-13 and B0-17 for another pot.
What’s went wrong?
Hey intosite,
you have to connect the unused J’s of your AIN4 to ground
Greetings, Romanoff
Do i still have to do that after i do the MT_EOT in the mios-table.ini file?
