Struct array by reference
Hello,
I take a array of struct to organize my data and want to reset this data array in a seperat function,
When I do so I get a compiler warning like this:expect struct is data * baut argument is of struct data *"
in mwvb.c
static midi_waveboard_cards wtbCard[MIDI_WAVEBOARD_CARD_NUM];
function init() {
do something
     MIDI_WAVEBOARD_Card_Reset(&wtbCard[0], k);
The result is  that data in the strust[array] are not changed.
void MIDI_WAVEBOARD_Card_Reset(midi_waveboard_cards * wtbCard[0],u8 resCard ) {
do something
Can somebody help.
Greetings
Roman
Hi
the trouble with this topic is going on.
Hereafter the debug output (cutted by some line):
[17952.719] reset
[17954.801] [init] K Emu : 0
[17954.801] [init] Emucount : 3
[17954.802] [initCard] CardNum : 0
[17954.802] [initCard] I : 0
[17954.803] [initCard] PartGrp : 1
[17954.803] [initCard] PartPrg : 1
[17954.803] [initCard] CardNum : 0
[17954.803] [initCard] I : 1
[17954.804] [initCard] PartGrp : 1
[17954.804] [initCard] PartPrg : 1
[17954.804] [initCard] CardNum : 0
[17954.805] [initCard] I : 2
[17954.805] [initCard] PartGrp : 1
[17954.806] [initCard] PartPrg : 1
[17954.806] [initCard] CardNum : 0
[17954.807] [initCard] I : 3
[17954.807] [initCard] PartGrp : 1
[17954.807] [initCard] PartPrg : 1
[17954.808] [initCard] CardNum : 0
snip…
[17954.821] [initCard] I : 13
[17954.821] [initCard] PartGrp : 1
[17954.822] [initCard] PartPrg : 1
[17954.822] [initCard] CardNum : 0
[17954.822] [initCard] I : 14
[17954.823] [initCard] PartGrp : 1
[17954.823] [initCard] PartPrg : 1
[17954.823] [initCard] CardNum : 0
[17954.824] [initCard] I : 15
[17954.824] [initCard] PartGrp : 1
[17954.824] [initCard] PartPrg : 1
[17954.824] [sNDBANK_DATA] ix : 1
[17954.825] [sNDBANK_DATA] value : 0
[17954.825] [sNDBANK_DATA] Result->prgnum : 1
[17954.826] [sNDBANK_DATA] Result->banknum : 0
[17954.827] [sNDBANK_DATA] Result->name : GrandPno
snip…
[17954.829] [afterInitCard] CardNum : 0
[17954.829] [afterInitCard] I : 0
[17954.829] [afterInitCard] PartGrp : 1
[17954.831] [afterInitCard] PartPrg : 1
[17954.831] [afterInitCard] CardNum : 0
[17954.831] [afterInitCard] I : 1
[17954.832] [afterInitCard] PartGrp : 1
[17954.832] [afterInitCard] PartPrg : 1
[17954.833] [afterInitCard] CardNum : 0
[17954.834] [afterInitCard] I : 2
[17954.834] [afterInitCard] PartGrp : 1
[17954.834] [afterInitCard] PartPrg : 1
[17954.835] [afterInitCard] CardNum : 0
[17954.835] [afterInitCard] I : 3
[17954.835] [afterInitCard] PartGrp : 1
[17954.836] [afterInitCard] PartPrg : 1
[17954.836] [afterInitCard] CardNum : 0
snip…
[17954.849] [afterInitCard] I : 13
[17954.848] [afterInitCard] PartGrp : 1
[17954.848] [afterInitCard] PartPrg : 1
[17954.849] [afterInitCard] CardNum : 0
[17954.849] [afterInitCard] I : 14
[17954.849] [afterInitCard] PartGrp : 1
[17954.849] [afterInitCard] PartPrg : 1
[17954.849] [afterInitCard] I : 15
[17954.850] [afterInitCard] PartPrg : 0
[17954.850] [midi_labels] size of sndData : 7924
[17954.850] [midi_labels] sndDataArrayCount : 566
[17954.850] Init DHCP
[17954.937] [network_device_init] PHY initialized
[17959.843] SD Card not found
As you can see the last PartPrg is not changed after init. What could be happens?
BL excluded is = 3FFF; Reached that the border of first memory block?
It would be great if you could help me.
Roman
It’s really hard to guess what your problem is unless you show some actual source and the exact compiler error. Anyways, here’s a working version if what I guess you are trying to do, maybe that helps.
typedef struct {
    int foo;
} foo_t;
foo_t bla[14];
void doIt(foo_t *data) {
    data[1].foo++;
extern "C" void APP_Init(void) {
    doIt((foo_t*)&bla);
    Log("%d", bla[1].foo); // outputs "1"
    doIt((foo_t*)&bla);
    Log("%d", bla[1].foo); // outputs "2"
I found the memory command in MIDI-Studio and enclose the output:
[19295.490] memory
[19295.493] Dumping the umm_heap…
[19295.494] |0x2007d328|B     0|NB     1|PB     0|Z     1|NF   850|PF     0|
[19295.494] |0x2007d334|B     1|NB     8|PB     0|Z     7|
[19295.495] |0x2007d388|B     8|NB    15|PB     1|Z     7|
[19295.496] |0x2007d3dc|B    15|NB    22|PB     8|Z     7|
[19295.496] |0x2007d430|B    22|NB    29|PB    15|Z     7|
[19295.497] |0x2007d484|B    29|NB    36|PB    22|Z     7|
[19295.497] |0x2007d4d8|B    36|NB   122|PB    29|Z    86|
[19295.498] |0x2007d8e0|B   122|NB   129|PB    36|Z     7|
[19295.499] |0x2007d934|B   129|NB   215|PB   122|Z    86|
[19295.500] |0x2007dd3c|B   215|NB   222|PB   129|Z     7|
[19295.500] |0x2007dd90|B   222|NB   393|PB   215|Z   171|
[19295.501] |0x2007e594|B   393|NB   400|PB   222|Z     7|
[19295.501] |0x2007e5e8|B   400|NB   571|PB   393|Z   171|
[19295.502] |0x2007edec|B   571|NB   578|PB   400|Z     7|
[19295.502] |0x2007ee40|B   578|NB   664|PB   571|Z    86|
[19295.503] |0x2007f248|B   664|NB   671|PB   578|Z     7|
[19295.503] |0x2007f29c|B   671|NB   757|PB   664|Z    86|
[19295.505] |0x2007f6a4|B   757|NB   764|PB   671|Z     7|
[19295.505] |0x2007f6f8|B   764|NB   850|PB   757|Z    86|
[19295.506] |0x2007fb00|B   850|NB     0|PB   764|Z   344|NF     0|PF     0|
[19295.507] Total Entries    18    Used Entries    18    Free Entries     0
[19295.508] Total Blocks   1193    Used Blocks    849    Free Blocks    344
[19295.508] Size of umm_heap is 14328 bytes, used: 10188 bytes, free: 4128 bytes
Sorry for delay in report this.
There are no compiler errors.
Roman
Hello,
I get answering myself again. I found a description of moving the array in upper memory and use it.
http://discourse.midibox.org/t/topic/16910
For the moment it seem solving the problem.
Greetings
Roman
