Having finished my Seq v4 (Wilba version), I am not slowly learning all the functions going through the manual.
Every now and again, the 8 encoders and 8 buttons underneath on the right hand side so not work.
Before I pull it apart and check for loose connections, could it be a button combination or something that causes this?
Sometimes all I need to do is push a button or turn or click an encoder on the left hand side and all is good again. Sometimes it takes pushing a few buttons. By pushing, I do not mean firmly, but just normal function.
Just occasionally some of the left hand side has this issue, on a random number of steps from the right. The first few steps are always ok.
The sequence will play all 16 steps OK.
Any ideas please?
EDIT: When switching on, it is always OK, so I reckon it is a button combination I am making in error.
I’ve just been using it for a few hours and no problems until just now. Then suddenly the right encoders didn’t work when I went to Edit Event. I had just come out playing a midi file (still testing the various functions).
I went to pattern mode, changed a pattern on the left and now the right side is all ok again. Weird.
EDIT: Also noticing that the Mute LED stays on for a while after leaving mute mode.
Fixed the strange operation of the encoders. Started to strip it down, gave all the IC’s a push and one had a little give before it was in firmly. Switched it on and perfect!
Just the MUTE button stays on now. I found if I press the Pattern and then Song buttons, it clears it.
