Strange Error again
Hallo!
I wrote something like:
----------------------- VERSION that works ---------------------
void switchLEDs(unsigned char pattern, unsigned char and){
  unsigned char i;
  unsigned char pos;
  for (i = 0; i < 8; i++){
      MIOS_DOUT_PinSet1(32);
      MIOS_DOUT_PinSet1(33);
      MIOS_DOUT_PinSet1(34);
      MIOS_DOUT_PinSet1(35);
      MIOS_DOUT_PinSet1(36);
      MIOS_DOUT_PinSet1(37);
This works.
BUT: all trials to make the pin setting dynamically depending on i failed!
----------------------- VERSION 1 that does not work  ---------------------
  unsigned char i;
  unsigned char pos;
      MIOS_DOUT_PinSet1(32 + i);
This do not work, even if I use the temporär variable pos to store the result
of 32 + i. I thougth: ok, if it is a compiler bug and MIOS_DOUT_PinSet1 needs a contant parameter I reprogrammed it:
----------------------- VERSION 2 that does not work  ---------------------
  unsigned char i;
  unsigned char pos;
  MIOS_DOUT_PinSet1(37);  //see below!
      switch(i){
        case 0: MIOS_DOUT_PinSet1(32); break;
        case 1: MIOS_DOUT_PinSet1(33); break;
        case 2: MIOS_DOUT_PinSet1(34); break;
        case 3: MIOS_DOUT_PinSet1(35); break;
        case 4: MIOS_DOUT_PinSet1(36); break;
        case 5: MIOS_DOUT_PinSet1(37); break;
This didn’t work, too. No pin is set, except pin 37. This was to indicate the function itselfs is called. I tried another version, with ifs:
  unsigned char i;
  unsigned char pos;
      if (i == 0) MIOS_DOUT_PinSet1(32);
      else if (i == 1) MIOS_DOUT_PinSet1(33);
      else if (i == 2) MIOS_DOUT_PinSet1(34);
      else if (i == 3) MIOS_DOUT_PinSet1(35);
      else if (i == 4) MIOS_DOUT_PinSet1(36);
      else if (i == 5) MIOS_DOUT_PinSet1(37);
Even this did not work! Only LED 37 ligths.
If I look at the *.asm the call of MIOS_DOUT_PinSet1(constant) is always the same. Independently if there are switches or ifs around it. But only the “pure” constant method above works.
I have no ideas. The *.asm seem to be ok.
As you can guess, the parameter “pattern” is the bit-pattern which of the LEDs 32-37 shall lit. But this is future…even the primitive varants do not work.
I have no idea.
Hi Thomas,
which SDCC version are you using? 2.6.0 sometimes behaves strange, 2.5.0 works ok - undefined snapshot versions (with immediate bugs) shouldn’t be used.
What happens when you are adding following code to the switchLEDs function:
  unsigned char i;
  unsigned char pos;
  MIOS_MIDI_BeginStream(); // for debugging
  MIOS_MIDI_TxBufferPut(0xf0);
      MIOS_MIDI_TxBufferPut(32 + i); // for debugging
      MIOS_MIDI_TxBufferPut(MIOS_DOUT_PinGet(32 + i)); // for debugging
  MIOS_MIDI_TxBufferPut(0xf7); // for debugging
  MIOS_MIDI_EndStream();
[/code]
Hi Thorsten!
I’m using 2.5.0 #1020 (8.Mai 2005).
But I could solve the problem.
The main problem was that in reality the 8 in the for-statement was no a 8, but a defined constant.
for (i = 0; i < (NO_OF_BUTTONS - POS_OF_SPECIAL_LEDS); i++) …
where
#define NO_OF_BUTTONS 40
#define POS_OF_SPECIAL_LEDS NO_OF_BUTTONS - 8
I forgot the brackets - changing it to:
#define POS_OF_SPECIAL_LEDS (NO_OF_BUTTONS - 8)
seems to work.
That my mistake.
BUT:
  1. during debugging I changed it to “8” sometimes - no result.
  2. The resulting *asm depend if there are only constants or a variable parameter in the for-block.
Assuming that in th upper case POS_OF_SPECIAL_LEDS is defined as NO_OF_BUTTONS so (NO_OF_BUTTONS - POS_OF_SPECIAL_LEDS) == 0.
I would assume the for-statement is executed never. As it is.
But it is executed 8 times if ther are only constants in the body. Seems that the preprocessor calculates the values differently, depending on the body.
I changed your examble so that every time a complete MIDI-controller valus was sent.
Summary:
VERSION 1:
------------- in Header file -------------
#define POSOFSPECIALLEDS NO_OF_BUTTONS - 8
------------- in function file -------------
  unsigned char i;
  unsigned char pos;
  MIOS_MIDI_TxBufferPut(0xbb);
  MIOS_MIDI_TxBufferPut(0x00);
  MIOS_MIDI_TxBufferPut(0x11);
  for (i = 0; i < (NO_OF_BUTTONS - POS_OF_SPECIAL_LEDS); i++){
    MIOS_MIDI_TxBufferPut(32);                            //constant!
    MIOS_MIDI_TxBufferPut(0x22);
    MIOS_DOUT_PinSet1(32);                                //constant!
    MIOS_MIDI_TxBufferPut(MIOS_DOUT_PinGet(32)); //constant!
    MIOS_MIDI_TxBufferPut(0x33);
  MIOS_MIDI_TxBufferPut(0x44);
I got:
BB 00 11
BB 20 22…  90 times in sum!*
BB 01 33… 102 times in sum!*
BB 00 44
* the order is mismatched:
BB 20 22
BB 01 33
BB 20 22
BB 20 22
BB 01 33
BB 01 33
BB 01 33
BB 20 22
VERSION 2:
  unsigned char i;
  unsigned char pos;
    MIOS_MIDI_TxBufferPut(32+i);
    MIOS_DOUT_PinSet1(32+i);
    MIOS_MIDI_TxBufferPut(MIOS_DOUT_PinGet(32+i));
I only got: (as you would expect)
BB 00 11
BB 00 44
VERSION 3:  (The right one)
#define POSOFSPECIALLEDS (NO_OF_BUTTONS - 8)
  unsigned char i;
  unsigned char pos;
I got what I want…
BB 00 11
BB 20 22
BB 01 33
BB 21 22
BB 01 33
BB 22 22
BB 01 33
BB 23 22
BB 01 33
BB 24 22
BB 01 33
BB 25 22
BB 01 33
BB 26 22
BB 01 33
BB 27 22
BB 01 33
BB 00 44
Strange, isn’t it?
I don’t find this so strange - i is an unsigned variable, it can never be < 0
Therefore the behaviour of:
for(i=0; i<0; ++i)
is undefined and heavily depends on the C compiler implementation (a good C compiler prints a warning in this case)
P.S.: yes, those missing brackets are not uncommon, all of my students @work are making this error once during their practical year :wink:
Hi Thorsten!
I find it strange.  :-\
Your right. But the warning always says something like this:
"test.cpp:8: warning: comparison is always false due to limited range of data typ
e" (gcc, g++)
I will check this with Visual C++ later.
I always thought this statement was clear (always false) and is not undefined.
Maybe. But I knew that there must be brackets. I simply forgot them because I normally program JAVA (at work) and C++ and Python (at Home). So I never use preprocessor-directives for constants anymore (I read my Scott Meyers well… ;)) .
And all other variants don’t need brackets…
Hi!
FYI: Weil mich das jetzt sehr interessiert hat und ich (auf die Schnelle) darüber nichts finden konnte, habe ich die Frage in den einschlägigen Newsgroups gestellt.
Einhellige Meinung: die Bedingung müsste immer falsch sein, die Schleife nie durchlaufen werden. SDCC macht also hier sein eigenes Ding. (was aber nicht so schlimm ist, da es eh kein ANSI-C ist. Nur man muss es halt wissen.)
