My beloved MB-6582 has developed a problem with the rightmost menu button, i.e., the one used to select the SAV page.
It used to work, but now when I press it, it selects either the ENV or MOD page instead, irrespective of what page is actually shown above it. This means I’m no longer able to save any patches.
Does anyone know what the cause might be? Hardware or software? I’m not sure how to begin diagnosing it.
Just a guess, but I would inspect all the solder joints on the IC’s. Since the buttons are connected with a matrix, a stray blob of solder or some other bridge could cause weird results. I could swear there is a firmware you can upload that tells you which pin each button is connected to, but I don’t see it in the troubleshooting section of the MIOS8 uploads.
I’ve discovered that the problem stops if I completely detach the control surface from the aluminium front panel, which would indicate it’s causing a short somewhere. I think I can isolate it and fix it, but It’s 3 am now so that’ll be a job for tomorrow.
I bet all you need to do is put a piece of electrical tape on the LCD where it could touch the buttons above or below the LCD. I remember having weird stuff happen before I did that.
