Strange behaviour of PIC
have some issues with my 2nd CORE + PIC.
The CORE is working fine when i use the PIC 18F from the first core (e.g. the LCD display boot up and all is working).
If i am using the other PIC, i just get a “short” black line on the display upon booting then nothing;  however the reacting to SysEx &
reprogramming via Midi works (e.g. i see that with the LCD test application).
How can i see if the PIC is really defect or is there some possiblity to reprogram with _without_ a JDM (it’s ordered but not yet arrived). ???
greets
jan
*What* do you see?
And how (or by who) was the 2nd pic programmed? Is it possible it was programmed in Low Voltage Mode?
Bye, Moebius
>> *What* do you see?
With the LCD test application: nothing, just the MIDI output (on my Midibox).
When using the “programming” (e.g. 3 sec turnup) i see the bytes + ACKs from MIDI and from CORE.
The only thing i don’t see is anything on the LCD.
If i use the other PIC in the SAME box with the SAME lcd, the “problem” is gone.
Both PICS were programmed by Mike with the default values (0x0000000000) and the bootloader.
i will have my JDM next week
