STM32F4 Problems
unfortunately i have some two problems with my new STM32F4 core module.
I uploaded the actual bootloader 1.015 and Midibox NG 1.029 version.
This ports are wired J16, J8/9, J19, J15A and J15_S.
Problem 1:
The event Event Pool Allocation is 24480 of 24576 bytes (99%) exactly like
using the LPC1769 core. Shouldn’t be there more bytes available :question:
Problem 2:
The LCD does not work (backlight and contrast are ok).
It is a 2x16 HD44780 display.
I have triple checked the wiring and soldering.
TK, your help is needed :slight_smile:
Best regards
Marxon
Did you compile for the new target?
Edit: ok, I just saw that you can now download a binary version for STM32F4, and you skip compiling yourself. So, you are using that one?
Hi ilmenator!
I have not compiled something.
Just downloaded and uploaded to the core:
http://ucapps.de/mios32/mios32_bootloader_v1_015.zip
http://ucapps.de/mios32/midibox_ng_v1_029.zip
EDIT:
DIN, DOUTS and the SD card are working (if that matters).
Sorry if this is obvious: is J15_S set for 5V?
Yeah, it does not hurt to ask :wink:
J15_S is set to 5V
Best regards
Marxon
OK, open MIOS, clear your terminal screen and send load the Bootloader 1.015 hex file - not the MIDIbox NG application.
-> What does the terminal say at the very top?
For exmaple, my STM32F4 core isn’t hooked to and LCD or anything else and it says:
[386343.822] Initialize LCD #1
[386343.886] Failed - no response from LCD #1.1
[386343.886] Initialize LCD #2
[386343.950] Failed - no response from LCD #2.1
Also, I just compiled the MIDIbox NG application for the STM32F4 on my pc using the latest SVN source.
You can try it out: http://sneak-thief.com/MIDIboxNG/project.hex
It loads fine and gives me the appropriate message for my setup:
[387180.219] [MBNG_LCD] no response from CLCD #1.1
[387180.220] [MBNG_LCD] no response from CLCD #2.1
After uploading your .hex MIOS gives this output:
[78833.839] Init DHCP
[78834.846] SD Card connected:
[78835.015] [MBNG_FILE_C:317] WARNING: no CC number expected for EVENT_ENC due to type: Disabled
[78835.443] [MBNG_FILE_C] Event Pool Number of Items: 734
[78835.443] [MBNG_FILE_C] Event Pool Allocation: 24480 of 24576 bytes (99%)
[78835.450] [MBNG_FILE_L] DEFAULT.NGL hasn’t been changed; reading labels from existing DEFAULT.BIN file.
[78835.451] [MBNG_FILE_L] 7 labels found in /DEFAULT.BIN file
[78835.456] [MBNG_FILE_S] loading snapshot #13 from /DEFAULT.NGS
Entering “system” into the terminal gives this:
[78917.869] Application: MIDIbox NG V1.029
[78917.870] MIDI Monitor: disabled
[78917.870] MIDI Monitor Filters: enabled
[78917.870] MIDI Monitor Tempo Display: disabled
[78917.870] Print AOUT Config: TODO
[78917.870] lcd_type: 0x00 - CLCD
[78917.870] lcd_num_x: 1
[78917.870] lcd_num_y: 1
[78917.870] lcd_width: 16
[78917.870] lcd_height: 2
[78917.870] Event Pool Number of Items: 734
[78917.871] Event Pool Allocation: 24480 of 24576 bytes (99%)
I see there’s nothing about LCD’s, like mine:
[389191.893] [MBNG_LCD] no response from CLCD #1.1
[389191.894] [MBNG_LCD] no response from CLCD #2.1
[389191.894] Init DHCP
[389196.915] SD Card not found
Nope
But what does it say when you ONLY load the bootloader, like I asked above?
Mine again:
[389537.459] Initialize LCD #1
[389537.523] Failed - no response from LCD #1.1
[389537.524] Initialize LCD #2
[389537.587] Failed - no response from LCD #2.1
[389537.588]
[389537.588] ====================
[389537.589] Bootloader 1.015
[389537.599] ====================
[389537.602]
[389537.613] Checking Bootloader...
[389537.633] No mismatches found.
[389537.635] The bootloader is up-to-date!
[389537.651] You can upload another application now!
[389537.673] Or type 'help' in MIOS Terminal for additional options!
[79878.592] Initialize LCD #1
[79878.649]
[79878.649] ====================
[79878.649] Bootloader 1.015
[79878.660] ====================
[79878.662]
[79878.674] Checking Bootloader…
[79878.751] No mismatches found.
[79878.754] The bootloader is up-to-date!
[79878.769] You can upload another application now!
[79878.791] Or type ‘help’ in MIOS Terminal for additional options!
So, we can see that it’s “initialized”.
I think this output below only shows the stored CLCD config and NOT the actual one because it says the same on mine when I type “system” in the MIDIbox NG application:
And what does it mean?
At this point, the only possibilities are:
  1. Dead CLCD
  • time to test another CLCD?
  1. Something weird with the software and/or configuration
  • das Heisst: keine Ahnung… TK! Wo bist du denn? :stuck_out_tongue:
  1. Bad wiring between the STM32F4, the 74HC595 and the CLCD. Did you try another 74HC595?
  • time to post a picture of your wiring (both sides, high-res please)
  1. LCD works with LPC core
  2. Ehrlich TK, zu der Uhrzeit solltest du noch online sein :wink:
  3. Checked wiring 10 times. Also tried another 74hc595.
Damn! Kick me in my ass!
I checked everything… Really everything?
No, i left out the resistor array which turns out to be a 10k ohm array.
:angry: :angry: :angry:
This might be the problem!
I am going to change it and post result in some minutes…
It works!!!
:hyper: :hyper: :hyper:
Nice that you find the error! :slight_smile:
Here a preliminary version which provides more event pool memory for the STM32F4:
http://www.ucapps.de/mios32/midibox_ng_v1_030_pre1.zip
