my first post here in the forum…let’s start with a problem. If found similar topics in the forum, but my issue is a bit different.
I finished my STM32 Core Module with my own PCB design. PCB is OK, everything I tested seems to work so far. BUT, when connecting it via USB to my WinXP computer, it’s not recognized. I get the message that the device connected to the usb port was not installed properly and may not work. Then it’s listed as “unknown device”. I tried it in Bootloader Hold Mode, but same problem.
I’m usig a STM32RCT6 runnig with a 8 MHz crystal. I flashed it via SWD with a STLink device.
Is there anything I have to change in the software or configuration?
The datasheet of the STM32 says: “The high-speed external (HSE) clock can be supplied with a 4 to 16 MHz crystal/ceramic resonator oscillator.” So this should be no problem.
Unfortunately I’ve got no 12MHz Crystal at hand to test it.
Thanks for your help so far. I’ll be back for sure if something else doesn’t work…
PS: did you know, that Arnold Schwarzenegger at first did not want to say that: “I’ll be back”? He thought it sounded too feminine…little side information…unnecessary but funny…
