Hello!
For a stereo sid setup you need of course one core8 with the right pic. I don’t think the previous usual pic18f452 will work here. And you need 2 sid modules.
All the info needed on how to connect them modules together will be found in the midibox.org wiki and on ucapps.de.
Not having finished my own stereosid build quite yet, I can’t tell u too much firmware wise. I guess there is a stereosid application that can be loaded onboard, but not sure wich, or what the differences are.
And again, all info will be found on ucapps. Though it seems like a rather simple site on top, there is tons of information when you dig deep. The studying will be good for you also, since it makes u learn a lot about the platform.
Good luck, and have fun with the sid. I’m off planning a case for my mb6582. When I’m done I will have 10 sids in my arsenal hehe. They have its own mixing console hehe.
As for the Jacks, you can use either two mono jacks or a stereo jack. All depends on how u wanna connect it. If u have loads of channels like my 10 sids it makes sense to use a sterojack and save the mono inputs on your console for things that need preamp.
And yeah, u interface the second board to a connector to the same connector on the core. In other words, they are wired parallel. Except for 1 wire. From the second SID module, you extract one wire from the loom and connect it to its own onepin connector on the core, can’t remember what its name is right now. So…
All cables run from connector on core to connector on first sid. Then you cut on wire off at that point, and run the rest of them to sid2. Then one wire goes from core directly to sid2, in the place of the same one you didn’t bring with you from sid1. Sorry, a lot of confusing explaining here, but I believe the schem is on ucapps.de somewhere… Don’t remember what to look for atm…
