Hi frank,
you won’t change the resolution by changing the keybed. You will get the same results. The problem is the NG firmware. So if you need a higher resolution, than go with KB. I use it and it works great.
BTW: you can still use the break is make function by sending a SysEx command to the KB core.
Is there anybody who can answer these questions:
What sysex message I have to send to Kb to activate and deactivate the Break is make function for kb1 and kb2?
Is there any list of available functions controllable by sysex?
Can I send this message to standard Midi in?
Are there any special adjustments in KB which should be done for controlling by sysex?
Frank
