Ok ok ok ok ok…So I delorted my last thread because I’ve rethunk my project. Here’s what I intend to do:
I’m going to merge 3 LC’s and a several 64E’s into one chasis. The idea is to create a dedicated set of controlls instead of having to flip through banks of sorts and only having control of one paramter at a time. There will be 24 channels each with 4 bands of EQ (freq/gain/q on each band) as well as a dedicated pan knob, and of course the mute/solo/rec/select buttons for each channel. Instead of doing full-out meters, I’m just going to put an RMS/Peak LED on each channel just for reference. I’m going to do something a bit more advanced for my ACTUAL meters.
I will have my transport, jog wheel, 5-way zoom toggle, timecode etc etc. I’m going to use the two 2x40 LCD’s just to label each channel. I tend to use my monitor a lot, the LCD’s are just for reference.
Now for the questions, brace yourself, I have a few.
From what I’ve gathered, this is the list of functions supported by the LC. I put “?” next to functions who’s purpose is a mystery to me. If anyone could explain them, it would me most appreciated.
Automation
Touch ?
Trim ?
Write
Read Off
Latch ?
Util. Enter ?
Util. Cancel ?
Hold Layer (I understand the purpose, I just don’t get how this function is controlled)
Function (I assume these are just misc. buttons that can be used for whatever)
F1-F8
Global (My impression is that this changes the function of the faders. I.e. it switches their control from tracks to outputs to buss’s to aux’s etc. However, there are still a few of these that don’t make sense.)
Audio Instrument ?
Audio Track ?
Inputs
Tracks
Aux
Busses
Outputs
User ?
View ?
Drop ?
Cycle ?
Nudge ?
Marker ?
Replace ?
Click ?
Shift
Option (does this do anything in Windows?)
Ctrl
Cmd/Alt
Flip ?
Bank (What is the difference between Bank L-R and Channel L-R?)
Left
Right
Channel
Left
Right
Assign (My impression is that this changes the assignment of the Encoders atop each Fader in the LC. However, since my plan is to dedicate these encoders to Pan, I don’t really need these functions. Right?)
EQ
Instrument
Plug-in
Pan/Surround
Send
Track
I will be working in Cakewalk SONAR 5, which is supported by the MCU.
Like I mentioned, I will be adding a dedicated EQ section on every channel as well as a side section of misc. encoders to be used to control VSTi’s, plug-ins, and robots to destroy Japan with. These will be part of the 64E inside the chasis. I will probably end up chaining CORE’s for this until I get enough encoders. My understanding is that the LC does NOT support chaining cores, but the 64 and 64E do.
I’m going to buy a MIDI interface to merge all the different signals and just send them out via USB to connect the whole mess to my compy.
I understand that I’m probably biting off more than I can chew with this project, but I’m confident enough in my abilities, and I will have help, as well as these forums ;D. I just need these questions answered (for now) so I can start blocking out my system and then work on ordering the parts etc. etc.
Thanks a ton. I really appreciate the help.
Dan
