This thread is basically just to see if anyone is interested in something that i’ve been thinking about for a while. I’ve unexpectedly got myself a 6581 SID, and I was thinking of things to do with it, and I was inspired by two things the ‘clones’ thread somewhere hereabouts, and a lovely little SIEL MONO I just fixed for a friend. I really appreciate the simplicity of its approach, and I was thinking of making something similar, based on the SID.
I’ve been thinking of integrating a single 6581 MBSID and Core module into a 3 octave keyboard, with external controls for things such as envelope etc. I’m not sure how many analogue inputs the MBSID core will support, but i’d like to have controls for everything, ie:
Envelopes
ASR for VCA
ASR for VCF/Pulsewidth
Filter
HP/BP/LP Switches (can use 1 or more simultaneously)
Cutoff
Resonance
LFO
2 x LFO’s with variable waveforms
Rate
Depth
Patchable to VCA, VCF, pulsewidth, and Pitch/VCO
Waveforms
3 x Pushbuttons to select waveforms for each oscillator (ie, sine, pulse, triangle and Noise).
Level controls for each voice.
I also thought it would be a good idea to have patch cables, to route the control voltages. For example, to patch LFO 1 to the filter, or to the LFO for Psuedo sample hold etc. In this way, it’s possible to build up a semi-modular synth, a little like the MS-20.
Obviously, the amount of controls available will depend on the amount of CV that the core supports (I count 17 seperate analogue parameters). I know that all this is possible with the existing design and control surface, but it’s not the same as having a nice little Mono synth like the SH-101 in front of you just begging to be tweaked!
Obviously i’m going to have a full MBSID + Control surface too, I just want something that doesn’t need me to read an LCD or whatever. Ideally, this design wouldn’t even need an LCD. Wherever the knobs/sliders are set, that’s what they’ll sound like.
Ermm, ok that’s turned into a bit of a waffle but you get the general idea of what i’m poking at.
Is this a realistic project for me to get myself involved in? I have a lot of time on my hands, so designing PCB’s and stuff is not a problem, some of the code might be though!
