I’m calibrating my SSM2044 filters from the Seppomen bulk order, and I have a few questions:
First off they sound amazing, pre-calibration.
Questions:
The instructions on the wiki say to adjust breakpoint trimmers, P3 and P4, to “mid” using a multimeter. When I use my multimeter to measure the voltage at the trimmers I can only get a reading (~3.43v) on P1 and P2, but no reading on P3 and P4. Am I missing something? Are P1 and P2 the breakpoint trimmers by chance?
By “mid” the wiki means ~5.33v, correct?
Do I need to worry about doing extra cutoff adjustments on the AOUT_NG if I already have calibrated the channels with a multimeter?
P3/P4 are for the breakpoint. This setting is only meant as a starting point and doing measurements there won’t give much reasonable readings. Just try the “mechanical” approach - these trimpots usually have 22 turns from one end to the other, so if you turn the trimpot in one direction until it starts making a clicking sound and then turn it back about 11 turns, you’re fine.
yes please do worry The SSM module doesn’t have any means of adjusting gain and offset of the cutoff, so you will need to use the respective trimpots on the NG to calibrate/tune the filter cutoff.
You could also measure the resistance, at least that’s what i did.
My trimpots are already soldered. My understanding, forgive me if I am misguided, is that you can’t measure the resistance of a specific component if it is already inserted into a circuit. There is no way to isolate it.
BTW, since you might be reading this Seppoman: Thank you for this fantastic module! I love it!
If you had a resistance in parallel, you would get wrong values indeed,
but as you can see in the schematic, if you measure between pins 1 and 2 of P3/P4, there is nothing in parallel.
If you measure between pins 2 and 3, there is a 100k resistor and a capacitor in parallel which don’t change much.
Thanks for the response. I hadn’t thought about it that way, but it makes sense. I’m actually having some troubles setting the resonance on mine. It seems that when I turn the resonance all the way down on the MB-6582 I get a audible buzz, and I can’t get them to self-oscillate either. I don’t own a scope, so I may try and take everything over to a friend that owns one and make my life a bit easier. I used the caps that Seppoman recommends so I am assuming that I shouldn’t have too much trouble reaching self-oscillation.
As I try unsuccessfully to get my SSM2044 to self-oscillate I have a question.
When using my MB-6582 to calibrate it I should set cutoff and resonance fully open, and turn off all oscillators. I then should play a note (say an E4) on my keyboard (controlling the MB-6582), and adjust the gain (P1) until I get self-oscillation. And the waveform coming from the filter should be close to the note I am playing on the keyboard, correct?
The reason I am asking is because this isn’t working out for me :sad:
So is your problem making the filter oscillate or getting a playable/tuned oscillation?
Playing well-tuned oscillation isn’t as easy as just setting everything to max and play The mbsid parameters routed to some target (like cutoff) add up together, so if you set cutoff to max, you’re already at the top frequency limit. What you need to do is set keytracking to 127, i.e. output value will track the keyboard position, and then the (initial) cutoff value will be your “master tune”. Getting a nice result requires good calibration and some tweaking time.
Right now I am stuck on trying to get the filter to self-oscillate, and having no luck. Just for clarification, I don’t need to have any audio going into the filter to get it to oscillate?
I inverted the channels, and I can play audio through the filter fine. The cutoff works, and, depending on the gain trimpot setting, when I turn resonance up with the filter open the audio signal gets a tiny bit quieter… No self-oscillation.
I am using exactly the same caps as seppoman so I doubt that is the reason, at least not for me…
Yeah, my intuition makes me think it isn’t the caps that I am using, as they have worked for other filters just fine… I’m a little stuck on the cause, so I’ve been focusing on other projects for a bit…
I had a look at the schematic and the SMM2044 datasheet. The datasheet says: “The sense of the Q control is from GND up with minimum resonance at GND.” Now, when I measure the voltage at pin 2 of my SMM2044s I get a reading of about -7 to 1 V or -5 to .5 V depending on trimmer setting max / min. It doesn’t look right to me. The control voltage into the board is from 0 to 10.6 V which should be right for Q. I don’t understand how the LM13700 cirquit works but I guess there is something wrong in there somewhere…
Also I have tried another board. Behaves the same.
I just measured those values: -0.1 to 10.9V into the module and -11v to 1.13v on pins2 of the chips ( from lowest to highest res.)
I think those -11v are strange, they only occur, when res is almost turned down completely, when turned up a bit, it jumps to around 0.5v and then can be adjusted precisely until 1.13v, where the filter starts to oscillate.
Maybe some more gain on your Aout could help?
Thanks Imp! Since I know your setup works, now I have something to go on. I think the jumpy voltages might have to do with linear expnential convertion of some cv… Anyway it seems strange to me with all the negative voltages, but it your work, then I guess it is right… I will try with some more juce from the aout…
The highest voltage I manage to get out of my aout_ng or rather into my ssm2044 is 11.12 V. This gives pin 2 of the SSM2044 a voltage of 0.84V. The lowest voltage is of course 0 V and that gives a -5.18 on the SSM2044. It seems I don’t get enough amplification… The power supply should be close enough to 12 V (-12.15 / +11.85). Now that I look at the numbers from my previous post it looks like I made things worse, but I didn’t check them carefully before, so I guess they are about the same…
