Next the meat of my concept, I use SMD components to make a 4x8 panel, with all shift registers on board. This allows the pcb to be tiled either right to left or top to bottom. This way with two boards I can make either the 4x16 MB-Seq duo matrix, or an 8x8 monome like control. With the interconnects being only serial, the usual spaghetti mess should be eliminated.
But first thing is that the MB-Seq duo matrix design needs improvement. As TK points out in his comment “CIRCUIT NEEDS TO BE IMPROVED FOR HIGH CURRENT LEDS!” the DEFAULT_SRM_DOUT_CATHODES<n> shift registers are sinking way more current than they can handle. In the seq the extreme case is 9 leds at once and should be rare. But for general case max is 16 leds, and with these lighting through silicon buttons, each will require more current than TKs. According to my calcs, and tests run by SmashTV seem to concur, the source shift registers should be able to supply >18 mA per pin with all firing. So for first stab at improving the circuit I added current sinking transistors to the led pins on each DEFAULT_SRM_DOUT_CATHODES<n> shift register:
NOTE: this requires inversion of those pins of the shift register in the seq software…
MC Cacasentenze, looks like you are on the wrong track - this is a DIY community, you are free to modify what you are offered here ;D. And “offered” is not meant in the sense of you pay you get something… more like: you get some recipe, modify it and give back your recipe. THAT would make you a valuable member.
..can i also use james nipply nipples pic for my account ? after all i ve been a long time fan club subscriber of the guitar throwing idol / nipples whipper .. uh?
and then why not adding ultraviolet and infrared leds ? you can get tanned and talk to extraterrestrian while MBing !
uh oh, mc, you’ve been outed. where’d you get that photo???
mmmmm maybe even better than led porn (the dark shot)
but i don’t need leds to talk to extraterrestrials…
