i know this is a stupid question… but what do you think is an handy and confortable spacing (both vertical and horizontal) for the pots of the midibox?
of, put in other words, how many millimeters did you leave between a pot and its neighbour?
i’m about to design my new midibox (with pic16F, 16encoder and 16 analog pot) and i’d like to optimize its dimension… making it as small as possible, but also as confortable as i can!!
I think, Roger met the point: studio mixers >35mm. The harmonized size in studio environment since years is ~40mm (Tonstudio DIN) – which gives you enough comfort for long mixing sessions. I tried on some dummy panels – due to exactly the same reason as asked in this original post. 25mm is too small. 30mm is just ok, but 35-40 is great. 45 is not necessary anymore. Too much space for nothing. I made exactly the same examination as Roger suggested: try several mixing consoles, professional as well as “hobby versions”. You will see the difference. Same is valid for the pushbuttons. Yesterday I had a conversation with a sales representative from EAO Lumitas, and checked the look&feel with the professional versions (series 95 and 97 for those of you who know EAO Lumitas). They supply their push buttons to a lot of professional mixing console manufacturers. There are really “worlds” between simple & cheap versions, and professional versions. And if you wanna get illuminated versions, it’s even more phantastic…
… Fairlight FAME uses 45 and just as Skunk wrote: It’s not really necessary, but…
I’ll have 45 on my LC, because that’s what I like on the Fairlight: You can place your hand over the fader, grab it with your index or middle finger, while the left and right part of your hand is placed on the panel and the other faders still won’t be disturbed in their movement by your hand.
