jeb
December 10, 2007, 2:34pm
1
hello,
i’ve made several small midiboxes (one year ago… see my other post)… i’m
currently building a new one, and i have one or two small questions…
what range has been tested for power ? is 12V AC ok or too much ?
is there an interface for a power led (i don’t want to build a ?OUT module
for this!)
i have 50 kohm faders… will it be okay ? i remember i had problems with
100k pots… will these 50k be okay ? if not, i don’t remember how to make
them work (i cannot replace them for my specific project!!) WITHOUT jitter…
any idea ?
thanks in advance!
SLP
December 10, 2007, 3:01pm
2
I think the 7805 can handle up to 18V input voltage.
2)Why don’t you just connect a LED with a resistor in series after or before the 7805?
3)they *should* work. I’m not sure. Why don’t you just test one on one of your working MBs?
matthias
Jeb,
I use a 13 volt ac wall wart with mine, no problems.
I also use 50k pots on my MoogModularV / MidiBox, some of the wires are longer than 18 inches so I occasionally get some jitter in those lines, changing to 10k pots on those farther runs seems to clear the jitter problems for me.
hope this helps,
gb
