Some questions about MIDIbox CV
Hi:
I´m about to build a MIDIbox CV using a AOUT module, as part of a modular
synth I´m building.
I have some questions:
1 - I want to add extra triggers using a DOUT as described here:
http://www.midibox.org/dokuwiki/how_to_use_midibox_cv_with_a_dout
Will this mod work with version 1.2a of the MBCV firmware?
2 - Will this mod increase the latency of the MBCV?
3 - I read in a post that the AOUT PCB didn´t have the power connected to the
chips and it has to be done with wires. Can anybody confirm?.. and explain to
what chips.
That´s all for now.
Thank you.
1 Will this mod work with version 1.2a of the MBCV firmware?
Yes.
No(t noticeably).
* You’ll need to specify which AOUT board you are talking about, as there are three different ones: AOUT_NG, AOUT_LC and the “regular” AOUT.
* Could you link to the post you are talking about, please?
Hi nILS Podewski:
Thank you for your reply.
The AOUT I´m building is the regular AOUT with MAX525 DACs.
The post I was reffering was this:
http://www.midibox.org/forum/index.php/topic,10412.0.html
But I think I understand what TK means.
I should connect +12 and -12 to both pair of pins around th TL074s, right?
Thanks again.
