Some midibox questions/suggestion
Its possible on the midibox sid aving two 6581 and two 8580, and use them like one big synth, taking the advantages of the different types and use them just like one big synth but configurable?
What about doing in a future a midibox sid board with the four sid in one board? I mean a big board with the four SIDs on it, a more solid board instead a lot of wires for connect them.
I’m working on a design for a quad SID midibox.  Right now it’s still in the design phase, but it’ll have everything you need for a full control surface quad sid synth on one board.  I’ve added a simple mixer to provide a mono output.  When the board is finished and tested, I’ll release foil patterns.  A note of caution: I don’t reccomend making a board from my patterns using an iron and transfer paper unless you know what you’re doing.  I had a horrible time getting even a halfway decent transfer with an iron.  I’ll be using a hot-roller laminator to do my tranfers from now on.  .032" board is also a good thing to try.  It cuts a lot easier than regular .062" board and can be run through an unmodified laminator.
