The problem: I need touch sensors. But I am no sure for the connection. The one pin of the switch will end up in the last DINX4 but the other pin sould it be ground or +5v?
Since the touch function works by grounding when you touch it which gives a difference in potential, I would say, you have to connect them to ground. I don’t know about you should connect it over a resistor.
Please search the archives… I think I once have seen a post, concerning this.
the panasonic mf’s dont have a touch track, u need to use buttons connected as norm to din, then just set em as mios emulated touchtracks…
From lc_io_table.inc:
;; 16th shift register
;; button LED
db ID_FADER_TOUCH_CHN1, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN2, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN3, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN4, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN5, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN6, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN7, ID_IGNORE ; (no LED supported by host)
db ID_FADER_TOUCH_CHN8, ID_IGNORE ; (no LED supported by host)
