Okay a few problems, looks like my FM is a little schitzo, I get a lot of messages over midi after turning it on without actually touching anything. One particular problem seems to be a consistant system reset. Is there anything I should be looking at that might cause a system reset?
Also there’s nothing but static coming from the outs.
Check and double check resistors, near DIN, AIN port, sounds like “floating pins” i.e. they don’t know if they are a 1 or a 0 and a hand over the pic will be enough to make it crazy.. so make sure you have them, they are not optional!
It says on the LCD “MIOS 1.9d” at least once, where sometimes it repeats it (goes blank and then says “MIOS…” again). Then usually it says some musical/midi value “blah 127”.
The MIDI in monitor gives loads of settings changes as well as an [ff] reset log. It appears as if (to me at least) the FM program is indeed loaded and is running to whatever extent.
Okay reflashed without any bankstick or presets (or even the bankstick plugged in). I actually says it’s starting up Midibox FM, and appropriate (seemingly) lights ligt up on the console. But unfortunately the sound coming out of the FM is a horrible modem like thing. No more weird midi messages but there is always a creepy sounding hum ,and when I press the keyboard there’s a really weird howl that emanates from the box. Anyhow had this as well?
Also I can’t control the HUID at all for some reason, everthing is wired but not a single button gives a response from the LCD or any LED
You might want to try one of the test apps for your buttons.
One thing at a time is good First, fix the core. Then the DIN/DOUTs. Then the FM. You’re going about things in a very random manner right now, and I don’t think it’s helping you too much…
As I said I guess I fixed the core by reflashing, no more weird midi signals. Now I loaded the sine wave app and it’s acting really spasmodically. I was able to load just one amp at a time, in the one socket (the one with a different orientation). Each individual amp actually worked. Then after checking all 3 in this manner (same place alone), they turn out fine. But if I plug 2 into the module, it will then not work anymore at all
Crap, so I guess no one has any pointers? I’ve tinkered around quite a bit with no results. So far I swapped out the entire FM module for another one + all the amps with nothing positive happening. If no one has any suggestions then I just mad a large brick.
i cant help you with specifics as i havent made an fm
but here are some things ive found to help
going away and doing something else for a while coming back to it refreshed
finding another pair of eyes someone who can understand whats going on but isnt so emontionally involved with the project just to check for obvious mistakes that you cant see because youve been staring at it for the last two weeks
and as stryd said be very methodical and logical in your fault finding
regards and good luck kris
ps i dont believe youve made a brick but the question is do yu believe you have
Okay, well I’ll give it a few days. I guess there isn’t much of a user base to plum for pointers. Was hoping someone could say “I had this problem, try this…”
