I was seeing an error on startup which read “SID 4 not available (CAN bus errors)”, along with a flashing top row of LEDs and flashing left column.
I searched the forum and found this thread, which gave me some direction:
Specifically this comment from Wilba:
On 10/11/2009 at 8:39 AM, Wilba said:
Just out of interest, try detaching the LCD from the CS PCB, keep it plugged in, just not mounted and away from any PCB.
A short between the LCD and the CS might be the cause. Maybe. Probably not, but quite a few people forget to insulate between LCD and CS PCB.
So, I disconnected my LCD from the control surface and the flashing LED issue went away, so I must have been shorting the tactile switches behind the control surface.
However, I’m still getting the same error whenever I try to access any SID module other than SID1…
For reference, I can confirm that all of the D1_CORE_ X _ diodes are in place, as well as R80. I’ve reflowed them to be sure the solder joints are good, but still no luck…
Perhaps I should replace the diode under Core1? Other suggestions?
Appreciate any insights.
