[SOLVED] MIOS32_AIN_CHANNEL_MASK
Might be really obvious but it’s not clicking for me.
// bit mask to enable channels
// Pin mapping on MBHP_CORE_STM32 module:
// 15 14 13 12 11 10 9 8
// J16.SO J16.SI J16.SC J16.RC J5C.A11 J5C.A10 J5C.A9 J5C.A8
// 7 6 5 4 3 2 1 0
// J5B.A7 J5B.A6 J5B.A5 J5B.A4 J5A.A3 J5A.A2 J5A.A1 J5A.A0
// Examples:
// mask 0x000f will enable all J5A channels
// mask 0x00f0 will enable all J5B channels
// mask 0x0f00 will enable all J5C channels
// mask 0x0fff will enable all J5A/B/C channels
// (all channels are disabled by default)
		#define MIOS32_AIN_CHANNEL_MASK 0x0000
If 0x000f is 15, how does that relate to J5A.A0..A3?
Thanks in advance,
Tom
Not sure where you got 15 from?
My interpretation is:
0x0CBA
Replace the letter with 0 if you want it disabled, f for enabled. They are groups of 4 channels (eg. A0… A3)
0x000f in decimal/base10 is 15. The reason I ask is because I’d like to disable all but the first mux (J5A.A0) so I only need to ground 7 inputs while troubleshooting/configuring.
It should be like this for A3…A0:
only enable A0: 1
only enable A1: 2
only enable A2: 4
only enable A3: 8
only enable A0 and A1: 3
only enable A1 and A3: a
enable all A0 to A3: f
Best, ilmenator
Ah my mistake, I was reading the pin numbers in place of the binary columns (for lack of better words).
J5A.A0 - 1
J5A.A1 - 2
J5A.A2 - 3
J5A.A3 - 4
J5B.A4 - 5
etc
instead of
J5A.A0 - 1
J5A.A1 - 2
J5A.A2 - 4
J5A.A3 - 8
J5B.A4 - 16
etc
Thanks for both of your replies. :slight_smile: Obvious after all!
