[solved] LPCXpresso Bootloader Problem
Hi *
Got a problem with installing the MIOS32 Bootloader.
I’m not sure if there is a USB problem.
I changed the USB cable. No difference.
I changed the XP Workstation - same result.
Found this:
http://support.code-red-tech.com/CodeRedWiki/LPCLinkDiagnostics
Here is the dfuapp.log output:
***DFU LOG FILE***
 Creation Time : dfuapp.log
Open Device
Get Device Descriptor successful
Get Configuration Descriptor successful
DFU Get Status successful
---> DFUStatus: No error condition present.
---> DFUState: Device is operating in the DFU mode and is waiting for requests.
 Device Descriptor
bLength: 0x12
bDescriptorType: 0x01
bcdUSB: 0x0200
bDeviceClass: 0x00
bDeviceSubClass: 0x00
bDeviceProtocol: 0x00
bMaxPacketSize0: 0x40
idVendor: 0x0471
idProduct: 0xdf55
bcdDevice: 0x0001
iManufacturer: 0x00
iProduct: 0x00
iSerialNumber: 0x00
bNumConfigurations: 0x01
DFU Get State successful
Download Block Nb 0 (2048 Bytes)
---> DFUState: Device has received a block and is waiting for the host to solicit the status via DFU_GETSTATUS.
---> DFUState: Device is processing a download operation. Expecting DFU_DNLOAD requests.
Download Block Nb 1 (2048 Bytes)
Download Block Nb 2 (2048 Bytes)
Download Block Nb 3 (2048 Bytes)
Download Block Nb 4 (2048 Bytes)
Download Block Nb 5 (2048 Bytes)
Download Block Nb 6 (2048 Bytes)
Download Block Nb 7 (2048 Bytes)
Download Block Nb 8 (2048 Bytes)
Download Block Nb 9 (2048 Bytes)
Download Block Nb 10 (2048 Bytes)
Download Block Nb 11 (2048 Bytes)
Download Block Nb 12 (2048 Bytes)
Download Block Nb 13 (2048 Bytes)
Download Block Nb 14 (1544 Bytes)
Download Block Nb 15 (0 Bytes)
---> DFUState: Device has received the final block of firmware from the host and is waiting for receipt of DFU_GETSTATUS to begin the Manifestation phase; or device has completed the Manifestation phase and is waiting for receipt of DFU_GETSTATUS. (Devices that can enter this state after the Manifestation phase set bmAttributes bit bitManifestationTolerant to 1.)
---> DFUState: Device has programmed its memories and is waiting for a USB reset or a power on reset. (Devices that must enter this state clear bitManifestationTolerant to 0.)
Device Reset after Download successful
 ***END OF FILE***
Any Ideas?
  • Contemplating Lemonhorse
Annotation: LED2 is always blinking - and it’s my first LPCXpresso :wink:
Are you using the lpc expresso software from the guys that make the chip?
cheers
Paul
I do use LPCXpresso 4.2.3.201205301041 (Code Red Technologies)
Did you already plug the LPCXPRESSO into the MBHP_CORE_LPC17 module?
This isn’t required and can cause such issues if you don’t follow my guide 100%
Most simple way: unplug the module, it will (resp. should) be powered via the LPC-Link USB port anyhow during programming.
Ahoi TK!
No, I only used the plain LCPXpresso board and followed Your guide [installing the MIOS32 Bootloader @ http://ucapps.de/mbhp_core_lpc17.html ].
Very strange… do you have access to another computer?
Yes, will try it on another Computer.
If it fails again, I will send the LPCXpresso board to someone who was already successful.
So I can exclude HW problems. I will post the results here.
Solved the Problem.
Solution:
VMware Player (4.0.4), Suse Linux 12.1 (32bit, with KDE) and LPCXpresso v4.2.3
It worked on the same (!) Host Computer (XP SP3 32bit).
:slight_smile:
Now the LPCXpresso LED2 is blinking 3 times (the last state = on).
