[solved] FM Output problem
Hi Midiboxers,
after fixing my voltage issue, i still have a output problem :frowning:
It is very low and there is a lot of background noise:
Testtone:
[test.mp3](< base_url >/applications/core/interface/file/attachment.php?id=10575)
I allready checked:
5V @ Ic1 Pin 1,7; Ic2 Pin 1, 3, 6, 9
+12V @ Ic3 Pin 4; Ic6 Pin 4
-12V @ Ic3 Pin 11; Ic6 Pin 11
polarity of c1, c3, c5, c7, c11 ,c16, c18, c20 ,c22, c24, c26, c31, c32, c33, c34 = checked
replaced Ic3, Ic6 = no difference
FM-Interconnection test = passed
Any suggestions what could be the fault?
May some other capaciator?
Thanks for your help
Best regards
Marxon
Hi again :smile:
I was reheating every soldering when i noticed a missing trace on my board.
It is the 5v trace which goes to the bridge and from there to the rest of the board.
But like i said in my last post there was 5v on Ic2 Pin 1, 3, 6, 9
even without the missing trace?
So the new question is: where do the 5v come from?
It´s me again…
But there are good news
Finally it works now :smile:
Good output, low background noise
I simply forgot to connect audio gnd.
Slap in my face…
And the 5v issue: who cares :wink:
