(SOLVED) Bug / problem with button MATRIX
Hi MidiBoxers,
Hi TK,
Last time I had a problem with MAPS which didn’t accept repeated values - TK solved this problem with version http://www.ucapps.de…v1_033_pre7.zip. Maps now working as expected.
But for the moment button MATRIX stopped working completely. Every time I press the button I get 1 of 8 values.
http://discourse.midibox.org/t/topic/18728
TK solved this with version: http://www.ucapps.de…v1_033_pre1.zip
Simply: with version pre7 - maps working OK, but Button Matrix doesn’t
with version pre1 - btton matrix works fine - MAPS don’t accept repeated values.
I have tested both versions - checked twice and confirmed.
here is a part of my ngc file:
DIN_MATRIX n= 1   rows=8  sr_dout_sel1= 3   sr_din1= 1  button_emu_id_offset=1001 \
                  inverted_sel=0  inverted_row=0  mirrored_row=0 \
                  sr_dout_sel2= 0  sr_din2= 0
works OK with version pre1, doesn’t work with pre7.
Help needed :smile: :happy:
Regards,
Hello again,
More detailed investigation…
My hardware:
STM32F4
2x DIN Modules
2xDOUT modules
I have 2 cores - I could repeat the problem on both of them.
I was trying to find the fault on hardware side - I checked my prototyping 8x8 button matrix few times - I couldn’t find a problem - so I decided to make another one. I took me few hours to make it, then I checked it again and again - looked good.
Connected everything to core - still the same problem. Changed DIN and DOUT boards - still the same. Finally changed core - still the same problem.
More detailed investigation:
There is always 1 button which starts the problem. Depending on script  / hardware configuration - there is always pair of pins which starts the crash. To prove it I used single wire with 1 diode to find which pins they are.
Also seems like DOUT module is the one which causes problem - doesn’t matter which shift register is selected on DIN module.
For this configuration:
DIN_MATRIX n= 1   rows=8  sr_dout_sel1= 1   sr_din1= 2  button_emu_id_offset=1001
DOUT:D7 <–> DIN:D0 is a bad pair. Connecting these two with diode will generate stream of messages (on/OFF) as long as the connection is hold. After selecting this pair - the whole first row of the matrix will go crazy - every button will send 1 of 8 numbers assigned to buttons in the row. If any of these buttons is pressed - it will then affect the column as well.
For:
DIN_MATRIX n= 1   rows=8  sr_dout_sel1= 2   sr_din1= 2  button_emu_id_offset=1001
DOUT:D6 <–> DIN:D1 is a bad pair
For:
DIN_MATRIX n= 1   rows=8  sr_dout_sel1= 3   sr_din1= 2  button_emu_id_offset=1001
DOUT:D5 <–> DIN:D2 is a bad pair
For:
DIN_MATRIX n= 1   rows=8  sr_dout_sel1= 4   sr_din1= 2  button_emu_id_offset=1001
DOUT:D4 <–> DIN:D3 is a bad pair
Changing sr_din doesn’t matter - bad pairs remain the same.
I have checked few versions of the firmware:
1.032 Pre1
1.032
1.033 Pre1
1.033 Pre6
1.033 Pre7
All versions have the same problem with bad pairs crashing the whole button matrix.
Any help would be very much appreciated,
Regards,
Bartosz
Strange…seems like I am the only one who uses MidiBox NG with button matrix configuration…or maybe the only one who have this problem. :sad:
I have performed few more tests today.
Changed all cables connecting modules together - did’t help.
I have tested configuration with  4x8 , 4x16 and 16x16 buttons.
Unfortunately  - there is always “bad pair” which crashes the whole button matrix.
Can any of you try above configuration and let me know if the problem exist on your side??
I am simply running out of ideas - t took me 3 days trying to find the hardware problem - and no results… :sad:
Regards,
Bartosz
I need more information to understand (and/or reproduce) the problem.
  • how is the core module supplied? Did you already check voltages (e.g. ca. 5V between Vs and Vd at the DIN/DOUT modules?)
  • could you please show a picture of your hardware? This may describe more than 100 words… :wink:
  • enter “set debug on” in MIOS terminal, then trigger the crash - which messages are displayed?
  • your .NGC file might also help to understand the configuration.
Hi TK,
Problem solved.
No problems with voltage - nice stable 4.97V all time - 4000 mA stabilized power supply.
Problem was with my ngc file …
If I write something like:
event_button id=  1002 fwd_id=LED:2    type=NoteOn chn= 1 key= 39  range=  0:127  offset=  0  ports=10001000000010000000  lcd_pos=1:1:1  label=“^std_btn”
with:
DOUT_MATRIX hardware
DOUT_MATRIX n=1   rows=8  inverted_sel=0  inverted_row=0  mirrored_row=0 led_emu_id_offset=1001 \
                   sr_dout_sel1= 1 sr_dout_sel2= 0  sr_dout_r1= 2 sr_dout_r2= 0  sr_dout_g1= 0 sr_dout_g2= 0  sr_dout_b1= 0 sr_dout_b2= 0
DOUT_MATRIX n=2   rows=8  inverted_sel=0  inverted_row=0  mirrored_row=0 \
and:
DIN_MATRIX hardware
It doesn’t work - even if there is no single physical diode connected. Simply button matrix and Diode use the same sr_dout.
With:
event_button id=  1002 fwd_id=LED:1002    type=NoteOn chn= 1 key= 39  range=  0:127  offset=  0  ports=10001000000010000000  lcd_pos=1:1:1  label=“^std_btn”
…Everything works perfect.
Regards,
Bartosz
Hi Bartosz,
I’m relieved that you found a way with the current firmware, because I’ve no explanation which change could have caused such kind of incompatibility. :-/
Hi Bartosz,
Hi Thorsten
With first (bad) configuration of ngc script I had button matrix using using the same DOUT shift register as directly connected LED. My understanding is as follow - button matrix was trying to trigger LED which was directly connected to DOUT without matrix. In this situation pin assigned to this LED is set to active. When I changed configuration to LED matrix everything works fine because in matrix configuration LED is never ON - it changes ON/OFF very quickly giving the illusion that is ON… I don’t know how to describe it… Anyway - button matrix couldn’t work correctly because one of the pins was always ON on DOUT module - and this same shift register was used.
I have posted more interesting case on “MIDIbox NG release + feedback” topic… I have found some more interesting studies and some workaround …but I am not happy with this solution …
Regards,
Bartosz
< base_url >/topic/17498-midibox-ng-release-feedback/?do=embed< base_url >/topic/17498-midibox-ng-release-feedback/?do=embed
