Hi all
I want to implement a smart select function for my controler.
The goal is simple, let say you have 8 button (and led) in a row,
if you push button 3 and 6, led 3,4,5 and 6 is active
if you push any button again, only this event is active
if you push then button 8 and 4, led 4,5,6,7 and 8 is active
etc…
Any strategy recommanded to achieve this ?
I like to avoid NRG for this function but right now I don’t see how to handle this with NGC only.
For the moment I have in mid NGR that get first(A) and second(B) value given by button N°
set a value(C) according to how many button are involved between, C=(B-A)+1
set a value(D) that give the button offset, D=A-1
then conditional for each event M,N,O…T like
if D<1 elsif C>8 set M=on
if D<2 elsif C>7 set N=on
if D<3 elsif C>6 set O=on
if D<8 elsif C>5 set T=on
I think I will also need a flip in case first button is higher count
like If C<0 then C=C-(2C)
As a delay (like 500ms) to let the system don’t wait forever if only one button is pressed
Input welcome
Best
Zam
