Smaller multiplexers?
;D This is my first post!  I’ve spent a couple days reading through all the information and my head is spinning.
I have an old JL Cooper FaderBaby, (16)20mm 100k slide pots fixed at sending ‘CC 7’ on each of the 16 midi channels.  It works great and is the reason I started snooping around for 'something more.'  Upon taking it apart, I found that it uses two small (maybe 1/4"x1/2") Motorola 14051B multiplexers (also has the code XAA430 printed on it).  Is there any reason I couldn’t find/use these itty bitty mults in place of the huge (in comparison) 4051’s?  If so, I’d try creating a layout plan for it so  others could make their own smaller boards.   Oh,  also, the FaderBaby has a small chip (can’t read the writing on it) that is obviously the ‘controller’ but doesn’t look like anything I’m familiar with.  I know it was never re-programmable (according to mr. Cooper himself at a NAMM show) so is it some sort of FPGA or what?    I’m not at home, and I can’t remember how many pins it has.
I saw somewhere on the site that TK was working on an FPGA of sorts.  Would this be a replacement to the PIC18F452?  It’d be fantastic for me to be able to have something much smaller than the current core board, but with the same programmablitiy/functionality.    I’d gladly help any futher research in any way that I can.  My soldering iron is tinned and ready to go! ;)
I haven’t been able to find any datasheets on the Motorola 14051b, or if it’s even manufactured anymore.  I figure someone has to make a similar part that’s just as small.  I want to make a control surface that fits in the palm of my hand with those same 20mm faders and add mute/solo/transport controls.
I realize that the core board is about as big as I want my whole controller to be, so I think I may have to make two boxes.  One that houses the core and a second to hold in my hand.
Any ideas on shrinking all this wonderful work?
8)-=Randy
Those are just Motorola branded 4051s in Surface Mount Device (SMD) Soic package, right? You’ll find those by other manufacturers too - make your own layout and those will work ok.
Bye, Moebius
p.s. Semiconductor division of the Motorola is these days known as FreeScale.
p.p.s. I think TK is playing around with his Spartan III fpga board, but we’ll just have to wait for the results  :wink:
Looking at the datasheet for the 4051, I saw a smaller SOIC package that is exactly the same size as the Motorola 14051B.   The mouser order number is CD4051BM going for $.54 one at a time and $.441 ea for orders of 100.   The datasheet for that model say’s it’s the same pin layout as the Mot.14051B!   (no big whoop, I know…fun untangling the riddles)   All the traces for the layout I have are on one side.  I’m thinking I should be able to fit 8 of them onto a board the same size as the existing AIN board.  Either all on one side, or 4 on each side.  Has anyone done this successfully?  Is there a reason why a board couldn’t have all 8 mults on it?
by the way, why can’t buttons be used via the AIN board?
Thanks for the info on FreeScale Moebius.  I see you posted just as I was typing this message.  So is a Spartan III fpga board a suposed replacement for the core?
-=Cheers
Yeah,
It’s the same part.. just remember that SMD parts are “mirrored” in relation to Thru-hole components  ;D
No. The reasons for MBHP designs are: A. Thru-hole components are easier to solder B. PCB size limit of the freeware version of the Eagle CAD C. Modularity.
I thought this was possible with some tweaks?!?
I think TK’s not going to “reinvent the wheel” or redesigning the Midibox, but looking for new challenges better suited for fpga than a microcontroller/PIC.
Bye, Moebius
