This would help reducing significantly the size of the boards.
Why not then make an ultra-slim sequencer/SID that can fit in a small suitcase ;D
If you go for it, maybe you can look at alternative chips (if they can easily be found in shops) that work in 16-bits instead of 8. I found some on the web for AIN, DIN or DOUT I don’t remember. That would also help reduce the size.
I have also been looking at some chips that contain a series of parallel resistors on them obviously for the din/dout boards.
after another look at the board desighn i think it will be a total redesign of the boards i think.
am i right in thinking that this would require some coding.
coding is definatly my weak spot :-[
but then again this is a concepts board, so fire away
