Simple Switch
Hello all.
Please be gently, I’m a MIDI noob.
My current setup is that I have a Boss GT8 guitar effects processor that has MIDI control, and a Hughes & Kettner Tubemeister 36 amplifier which is MIDI controlled.
I have this set up so that the GT8 changes the amplifer channel to whatever I need when I change the ‘patch’ on the GT8.
I need one more device to complete my setup;
Basically, I need to add another analogue effect into the chain when in one of two amplifier channels, and remove it from the chain in the third. So in effect, a simple effects loop switch.
I have attached a simple drawing of my idea on the concept, I just need to know how to make the midi part work and what components are required.
[Edit] - it appears that the file didn’t attach, maybe I need more posts on the forum to do that?
It can be found here:
Thanks!
Today MIDIbox is probably not the best choice for such a project, because the platform is designed for much more complex use cases.
This Arduino based project seems to fit for your purposes: http://forum.arduino.cc/index.php?topic=73418.0
Adding the MIDI OUT shouldn’t be a big deal. Either via software based forwarding, or via hardware (MIDI Thru circuit)
Thank you Thorsten.
